Tdi Loss of Turbo? - Page 3 - Defender Source
Old March 26th, 2010, 03:28 PM
is it possible you have an intake leak @ the head/manifold gasket?
Originally Posted by Wolf Fabrication View Post
Well, I swapped the boost gauge to the waste gate line and now can max out at 9.5psi, maybe 10 max. I'm going to fiddle with the wastegate linkage.....
Old March 26th, 2010, 04:17 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I routed the wastegate signal off the manifold so it opens a little later and now I can achieve a little over 10psi. I have threaded the wastegate linkage in a little more as well but have not tested it since. I think I am getting close
------ Follow up post added March 26th, 2010 05:37 PM ------
Just got back from a test drive. Maxed out at 12 psi! I think I will leave things alone at this point. Thanks for everyone's help. Not sure why the turbo crapped out in the first place, but through a combination of things everything seems to be fixed.
Cheers
Semper Fi!
tdi
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
200 tdi Turbo Retrofit Wanted 5 May 23rd, 2007 01:05 PM
TDI 300 Turbo Advice Eddie 1 Defender Technical Discussions 9 March 13th, 2007 05:22 PM
