Tdi injector's sealing corrugated copper washer - Defender Source
Old October 1st, 2012, 08:19 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Those washers have a circular protuberance, how are they suppose to go ?
- Charles Eames
Old October 1st, 2012, 11:29 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Already been discussed in this forum. Do a search on 300tdi injector seals or replacement for your answer
Old October 1st, 2012, 11:52 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Found the thread thanks, protuberance toward injector.
- Charles Eames
Old October 1st, 2012, 11:53 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Ouch?
Old October 1st, 2012, 12:00 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Make sure you clean out the "holes" before you put the injectors back in, and use a little grease to hold the washer on the injector.
Having carbon deposits down there makes for a bad sealing surface.
Old October 1st, 2012, 03:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The head was off, I cleaned those holes with little wood sticks... obnoxiously
- Charles Eames
tdi
300 tdi injectors - high pressure injector option for replacement? nathanwind Defender Technical Discussions 14 July 7th, 2017 03:00 PM
200tdi injector sealing washer? tomaco1 Defender Technical Discussions 7 September 8th, 2015 08:58 PM
North American Source for Bosch 300 Tdi Injectors? AggieD90 Defender Technical Discussions 5 June 29th, 2008 07:18 AM
