TDI Injection Pump Timing - Page 2 - Defender Source
Old April 22nd, 2015, 03:41 PM
Originally Posted by BRAB View Post
Yes the injectors were fine and the truck ran before the pump was replaced.
I have a new VNT turbo which is pushing plenty of air into it.
The pump is in the stock settings and has not been messed with
The timing belt is new.
The excess un-burnt diesel is white and the truck is barely running as is
you are cleared to proceed with Advance!
Mark Kellgren
KM4BOR
Old April 22nd, 2015, 03:47 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Would have done it hours ago but I have JOB
Need to get rid of the job so I can solve unsolvable problems
Old April 23rd, 2015, 12:07 AM
cdansan
Dan Clark
1996 Discovery
Works way better with the right FIP in it now.
Old April 23rd, 2015, 10:08 AM
BRAB
Brandon
Figured it out
Discovery and Defender 200TDI Pumps are not exactly interchangeable.
after swapping out the pump the truck started up easy and ran like a top.
Here is some data on the two pumps
Defender 200tdi, engine code 11L, 107 HP
ERR1333 ... Bosch # 0 460 414 080 ... Bosch type VE4/11F1900R347-1 ... single stage advance box: 9 degrees advance
Discovery 200tdi - engine code 12L, 111 HP
ERR459 (ERR0459) .... Bosch # 0 460 414 069 ... Bosch type VE4/11F2000R347 - double stage advance box: 7 degrees advance with 3 degrees start retard
ERR459 (ERR0459) .... Bosch # 0 986 440 212 ... Bosch type same as above - this Bosch # is used for exchange units, discontinued 10/2005
ERR1985 - for the Austrian market Discovery ... Bosch # 0 460 414 093 ... VE4/11F2000R462 - discontinued 05/1995
so on start up I may have bee experiencing 5 degrees of retard in comparison to the defender pump. Due to the injection pump sprocket being a tooth off I did not have room to advancce the timing and did not want to open the case to reset the cog in a different position. Swapped the pump using the tool in the timing kit, Got the injector pump timing pin lined up in the slot and it has been running great. Put 50mi on it since last night.
The VNT turbo is pushing 20psi max boost and spools up ridiculously fast.
EGTs are at 400f around town and hit 650 when hauling up some decent hills in 5th gear Overdrive at 60mph.
Fuel pin is at stock settings, I have a Morgan Hill Boost pin to install and i expect egts to rise to about 950-1000f when pushing the truck.
Intercooler is stock and exhaust has one resonator in it.
Thanks for the help. I will keep u guys updated with fueling data.
New hat from my brother came in the post when I got home in the Landy
Old April 23rd, 2015, 10:11 AM
supercharged67gt's Avatar
supercharged67gt
Andy
64 series IIa x3
its turbo timeeeeeeeeeeeeeeeeeeeeee!
Old April 23rd, 2015, 10:15 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
"New hat from my brother came in the post when I got home in the Landy"
I might have to beat you with a rolled up newspaper filled with fish and chips for talking like that.
Old April 23rd, 2015, 10:20 AM
BRAB
Brandon
Thought I would try and be funny... what i should have said is my My BRO sent me a sick hat and it was at my crib when i arrived in my poo brown hooptie.
According to urban dictionary
Old April 23rd, 2015, 10:43 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Please tell me where you can get fish&chips the old way, in rolled up newspaper, the EU banned that years ago in old country
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 23rd, 2015, 11:36 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Not a correct fish, but I brought a brown trout I caught to a buddy and he made me this
Old April 24th, 2015, 06:19 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Great information on the pumps. Good thing to look out for
tdi
2.8 tdi injection pump rayfi Wanted 6 September 18th, 2012 01:42 PM
Tdi Injection Pump Leak Wolf Fabrication Defender Technical Discussions 18 January 2nd, 2012 03:34 PM
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 10:19 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
