TDI Injection Pump Swap - Defender Source
Old April 16th, 2015, 10:18 AM
BRAB
Brandon
200TDI in a RHD 1986 D90
Looking to swap out my injection pump on my 200tdi in place on the motor.
Found this video
But am looking for some tips and tricks if any.
There are bubbles that are coming out from the front of the injection pump at the seam of the two halves of the casing right near the banjo bolt fuel supply. I have attached a photo for reference
Truck idles rough but smooths out upon giving it some gas, drove it for 10 miles no problem, then I nailed it in third gear brought the RPMs up really high let off the gas quickly and engine cut out. I tried to restart it with the key while rolling didn't do anything pulled over and tried to start it wouldn't start then I rolled back and bump started it and it started. I got right on the gas and it cut out. Bump started it again and let it idle and it cleared up and then got on it in third and and it cut out. Then I started it and waited for like two minutes and drove 2 miles with no problem being easy on the throttle. I assume if i got on it hard it would stall out.
I checked out the fuel system prior to that for leaks and there are none that are visible, I pressurized the line with an electric pump and there are no leaks. Fuel lift pump is new.
Thanks for the help, will swap the pump tonight and see if it solves the problem.
Brandon
tdi
300 tdi injection pump swap Uncle Douglas Defender Technical Discussions 22 December 1st, 2013 10:12 AM
Tdi Injection Pump Leak Wolf Fabrication Defender Technical Discussions 18 January 2nd, 2012 03:34 PM
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 10:19 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
