Tdi Injection Pump Leak - Defender Source
Old December 30th, 2011, 03:45 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Anyone with a Tdi experience a diesel leak from the injection pump where it bolts to the timing cover?
I assume there's an out seal in there somewhere....
Semper Fi!
Old December 30th, 2011, 03:58 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Sounds like front shaft leaking... i'd want to pull the front cover off of the timing chest and see if my belt was saturated with fuel.
Think it's going to be a pump off and send away job for repair.
Old December 30th, 2011, 04:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
Wouldn't I have fluid coming out the drain hole in the bottom if that was the case?
Semper Fi!
Old December 31st, 2011, 02:19 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'd have thought you would have fuel coming out the drain hole, it's the path of least resistance. Are you absolutely sure the fuel is leaking from the inside of the pump? Could it be a fault external to the pump.
Major pain in the wallet if it is the pump
Is the pump tight on the timing belt chest?
I'd clean up the area and verify where the fuel is leaking as a first step. There's a little inspection cover held on with 3 fasteners, I'd pull that and have a peak inside.
Mike Hammond
Old December 31st, 2011, 02:27 PM
Wolf Fabrication
Sterling Archer
'08 D3
Haven't delved in to just yet, but I did crawl under and poke around.
Definetely need to clean up the area and verify leak, but it's wet underneath and by the case. I'm hoping it's something loose.
Semper Fi!
Old December 31st, 2011, 04:04 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I thought mine was leaking too but was the return line. New line , no leak.
Land Rover 110
Old December 31st, 2011, 05:02 PM
Wolf Fabrication
Sterling Archer
'08 D3
I hope it's thats all it is...
Semper Fi!
Old December 31st, 2011, 06:43 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Put a seal kit in it. You can buy them on Ebay. Buy the special 3 sided socket tool. VEs all piss fuel if they have the old non ULSD seals in them.
JL
Old January 1st, 2012, 11:57 AM
Wolf Fabrication
Sterling Archer
'08 D3
So the leak is coming from the top of the pump at the bolt noted by the screwdriver. Thoughts? It's not loose either.
Semper Fi!
Old January 1st, 2012, 12:42 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Governor shaft O ring.
http://www.vwdieselparts.com/forum/viewtopic.php?t=6694
Seal kit would do it, you have to pull the top cover.
JL
Old January 1st, 2012, 01:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
Are you sure we are talking about the same bolt? The reason I ask is that this bolt won't come out unless I remove the pump itself. Does the seal you are talking about share the same passage as the bolt?
I was able to back it out 1/4" and clean it up with air and pipe cleaners. Someone else had already tried to RTV it. I put some Loctite on the threads and washer and will see if that holds.
Semper Fi!
Old January 1st, 2012, 01:42 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Oh, you definitely have to pull the pump, but at least you don't have to pull all the internals. They are a pretty simple pump to mess with. The link I sent you should give you an idea of how it all comes apart. I think the local pump shop only charges 2-300 bucks for a reseal, might be best to find a place where you can just drop it off and get it done.
JL
Old January 1st, 2012, 01:53 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, that's the next step after I see if my bandaide holds.
Semper Fi!
Old January 1st, 2012, 02:12 PM
oilburner's Avatar
oilburner
JL
large pile of parts
If it is leaking from that O ring, chances are the advance cover, top cover, control shaft etc are going to eventually start leaking. The patch will buy you some time but I would put a seal kit in it to avoid further mess.
JL
Old January 1st, 2012, 02:14 PM
Wolf Fabrication
Sterling Archer
'08 D3
Should there be an O ring on that bolt? Mine just has a washer.
Semper Fi!
Old January 1st, 2012, 03:07 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Yep. It is further in, ahead of the threaded section. The link I sent you has a good pic of the part.
JL
Old January 1st, 2012, 08:53 PM
Capt Milks's Avatar
Capt Milks
Vally injection in Lynchburg re-built a pump for me. They seemed to do a good job.
Land Rover 110
Old January 2nd, 2012, 02:12 PM
Wolf Fabrication
Sterling Archer
'08 D3
So my Loctite patch worked, I'll see how long it holds. Thanks for your help!
Semper Fi!
Old January 2nd, 2012, 03:34 PM
mikeslandrover
Mike Hammond
Great web site.
Mike Hammond
tdi
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 10:19 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
300 Tdi fule leak Questions!! Buckon37s Defender Technical Discussions 13 February 28th, 2005 02:32 AM
» Defender Registry
Trooper
cwilder
Oliver
IvanKV
Add your Defender
