tdi guage part #s? - Defender Source
Old May 8th, 2008, 10:45 PM
Abrooks's Avatar
Abrooks
Tony Brooks
tdi guage part #s?
I'd like to replace the poorly functioning H2O temp guage (and sender) in the 110 and install an EGT guage and sensor as well as install a tach. Anyone have the appropriate VDO part numbers?
Many thanks!
Tony
Old May 9th, 2008, 09:40 AM
Pat's Avatar
Pat
Patrick M.
D90 '96 300Tdi 5 speed
Do you really need an EGT gauge?
in a stock 300Tdi I'd replace the original water gauge & sensor.
Water Temperature Sensor (1/8-27 NPT) 323-095
Water Temperature Gauge 310-105 (VDO Vision)
Besides the temperature indication a temperature alarm is also advisable, a twisted head is pretty expensive to fix.
Tachometer (0-6000 RPM) 333-158 (VDO Vision)
Old May 9th, 2008, 09:58 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Excellent, thanks. I would like to include an egt guage as well.
Old May 9th, 2008, 10:12 AM
There's also this:
http://www.defendersource.com/forum/...ad.php?t=11105
Old May 9th, 2008, 10:19 AM
Tony,
eguages.com is where Pendy (Rover Yota) suggested as well. Since this truck only has a speedo, fuel guage, and wayward temp guage you realy are starting with a blank canvas.
I'm thinking mud uk console from ee and, and........
Old May 9th, 2008, 12:07 PM
Replace them all.... Once you have one Vision gauge the rest look like crap.
http://members.shaw.ca/red90/maingaugesnight.jpg
and yes, I have a speedo ready to go in.
I'm not sure about the 300TDI, but on my 200TDI, I was able to get a VDO water temp sender that was a direct fit, part #323-026, 5/8" UNF. It also has a warning contact which I've hooked to a light and a buzzer.
BTW, why can we not post pictures in the posts here???
Old May 9th, 2008, 01:41 PM
The question is "why can't YOU post pix in the posts here" - everyone else can
Just go to "manage attachments" in the "additional options" box further down the reply to thread page and attach away.
Old May 9th, 2008, 02:52 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes egauges.com Vision series. Go wild!
I can talk you through your options if you like. Only if you do a thread on it so I can stop explaining everything to everyone about this topic.
JP
legend in my own mind
Old May 9th, 2008, 03:02 PM
OK, I should have said "why can't we display linked pictures here?" It must be specifically disabled to not work as this is the only board I've ever seen this.
Old May 9th, 2008, 03:36 PM
Abrooks's Avatar
Abrooks
Tony Brooks
JP
Let's make this the thread, then. Pat kindly listed some part numbers which are all still valid on the eguages site. I'd like to include an egr temp guage so that when you (Pendy) come to pick up your rigs you can help me tune up this motor and I can monitor temps
I'd think that oil pressure and temp would be nice to monitor, but defer to the diesel experts for guidance. As Doug said, I have a blank slate and with Charles giving me that nice MUDUK console (thanks, Charles!) I've got a lot of space I can fill.
Old May 9th, 2008, 03:50 PM
pendy's Avatar
pendy
jim pendleton
89'd90
As it should be.
Water - Oil - Volt in the middle
Fuel - EGT - Tach - VDO speedo instrument panel
Thats gonna cost you! Do you have any driveway space? Any relatives with a towing business?
ID:	13379   Click image for larger version
Old May 9th, 2008, 03:53 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Good man! Now I just need all of the appropriate part numbers -- need guage and sender pns for Oil, Volt and EGT (don't make me actually do any work here, OK?)
Driveway space -- Check
Relatives in Towing -- no check, but I do know of a 90 that needs to be transported to CO . . .
Old May 9th, 2008, 04:03 PM
Pendy,
man-thats purdy
Old May 9th, 2008, 06:22 PM
Pat's Avatar
Pat
Patrick M.
Always for a 300tdi VDO Vision (used on my 90 300tdi)
Engine Oil temperature
gauge 300F 310-106
Sender: 300F/150C 1/8-27 NPT 323-057
Engine Oil Pressure (electrical)
0-80 psi gauge (10-180 Ohms) 350-104
Pressure Sender: 0-80 PSI/5 Bar with warning contact 7.0 PSI 360-009
I use the warning contact in parallel with the one that comes on the vehicle
Voltmeter
16 Volts Voltmeter 332-103
Fuel Level
Fuel level gauge 240-33 Ohm 301-105
I use an LR genuine sender for 90 Td5 and it works perfect, the genuine sender for 300tdi did not match the 301-105 gauge.
Boost
0-30 PSI 150-103 (I haven't installed yet)
Old May 9th, 2008, 06:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Outstanding, thanks! Now we just need a write-up on installing them all and we're set (OK, I'm set).
Old May 9th, 2008, 10:38 PM
Tony-
I should have been more specific in post #4, when I posted this:
It contains every piece of info you've asked for in this thread, write-ups from people that did the work, and a lot of trouble shooting experience from people solving problems.
Old May 9th, 2008, 11:33 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks Jim, I'll go back through the thread, though when I looked through it initially I missed and real mention of hooking up any senders to a tdi. I'll re-read it though.
Old May 10th, 2008, 12:09 AM
I went through and consolidated all the threads a while back. Trying to make them easier to find in searches - all the part numbers are in there, but it might be buried. I'm still trying to figure out how to call attention to all the best content.
Old May 10th, 2008, 09:10 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Does anyone make a pod to install another gauge somewhere? With the 2002 dash, I have limited room for gauges but plenty of room for switches...errrrr.. Im never happy
Legend in My Own Mind.
Old May 10th, 2008, 10:18 AM
Randy,
Mud uk makes a pop-up thats sits on top of the dash pad.
http://www.mudstuff.co.uk/images/0.gif http://www.mudstuff.co.uk/images/0.gifProducts > MudPod 40.00
The MudPod is another MUD designed solution that solves the problem of how/where to mount extra switches, controls and gauges into the Defender dashboard. The MudPod provides a neat and simple to install solution for competition users, expedition vehicles and emergency vehicles whose requirements demand additional dashboard space in order to accommodate auxiliary controls. The textured finish of the ABS moulding replicates the Defender dashboard texture to provide a 'factory' look once the MudPod has been installed.
part, tdi
300 TDI Block Heater Part # brn24whl Defender Technical Discussions 27 February 25th, 2017 10:55 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
