tdi guage part #s? - Page 2 - Defender Source
Old August 20th, 2008, 06:16 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Disco 200Tdi
I'm trying to replace a Disco 200Tdi temp sender. I went with John B's part number b/c I thought that the Defender and Disco 200Tdi's would be the same. Not the case. The photo shows the difference. I double checked the part that eGauges sent, it was 323-026D. The 026 was too long to even begin to thread in. I didn't match the threads up, guess I should do that.
Anyone know the correct VDO sender part number for a Disco 200Tdi?
-Neil
Old August 25th, 2008, 09:30 PM
weissbrewer's Avatar
weissbrewer
Stephen Johnson
94 AA D90
-Neil
bump, same question
94 AA Yellow D 90 ST/ disco 200TDI installed!Luvin 300+ miles per tank
1982 Series 3 HCPU gone but missed
Old August 25th, 2008, 09:41 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Stephen,
What I found out was that at NOT (normal operating temp), the resistance sent from the original sender was 90 ohms. As the engine cooled down, the resistance went up to around 200 ohms. I am going to experiment with some small resistors in series to up the resistance therefore moving the needle to match whatever the infrared temp gun reads on the waterpump housing as compared to the VDO gauge.
I'll post my results as soon as I get a chance to play around with it. This way we can just use our existing senders.
-Neil
Old August 26th, 2008, 08:53 AM
weissbrewer
Stephen Johnson
94 AA D90
Stephen,
-Neil
Thanx Neil, I am awaiting a mudpod for my vdo guages, and have my stock temp guage hokked up now. I guess this is not accurate according to my guy in uk. He says there is an adaptor and is looking for one untill I can find the disco 200tdi guage parts # source.
Steve
Old August 27th, 2008, 10:05 AM
Steve,
Could you post a shot or two of how you fit a disco 200tdi in your NAS 90 ? Just looking at the clearance to the steering shaft and box it would appear that would take some ingenuity that's beyond my realm to put one of these in a lhd truck. Very curious to see how you did it.
Old August 27th, 2008, 11:01 AM
weissbrewer
Stephen Johnson
94 AA D90
Red face
Originally Posted by Maryland 110
Steve,
Doug, I will try to get some shots tomorrow. I actually did not do the work, My freind (Matt Hawkes) who is a LR Master Tech in maine did it with Guru (in New England) Bob Veil s help. Look for pics tomorrow. The Steering shaft we just had machined in a straight fashion and a bit of cutting to clear the turbo. Have got some tweaking to do on cooling and intake filter arrangement. She is going to Matt Browne for ip tunning and all. I will neve drive a v8 again after owning the tdi........I likeee
Old August 29th, 2008, 06:36 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
...that's pretty funny.....
Matt Browne
Old August 29th, 2008, 07:53 AM
weissbrewer
Stephen Johnson
94 AA D90
sort of :O)
Old August 29th, 2008, 10:51 AM
weissbrewer
Stephen Johnson
94 AA D90
pics disco 200tdi in LHD 90
Doug, pics as requested
Old August 29th, 2008, 11:07 AM
cool-is that mated to the original lt77 ?
Old August 29th, 2008, 11:22 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
IT looks like the steering fits from the pictures. Is this true?
Legend in My Own Mind.
Old August 29th, 2008, 12:27 PM
weissbrewer
Stephen Johnson
94 AA D90
tdi fit
It is mated to a short bellhousing on the factory R380(original tsb replacement I think) with a short input shaft. Works great w/ GBR 4.10s and arbs I got from Jeromy in Texas. The truck is acually a bit quicker than it was with the cammed V8
The steering shaft is a custom straight job that Matt had machined and fits great.
Old November 19th, 2008, 12:12 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Stephen,
-Neil
Hi Neil-
Any resolution on this? If your ohm numbers are right, I wonder if VDO Gauge Part No 310-104 (220 deg) would work OK as it has a range of 240-33 Ohms. Here's a thread about drilling and tapping the original sender:
http://www.landroveraddict.com/smf/i...topic=361188.0
Hey Stephen - what ratio is your LT230?
Chance
part, tdi
300 TDI Block Heater Part # brn24whl Defender Technical Discussions 27 February 25th, 2017 10:55 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
