Tdi getting warm - Defender Source
Old September 2nd, 2006, 07:12 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Tdi getting warm
On the way up to Tahoe today the water temp started to creep...about half way to red from the middle on a stock LR gauge. This is not the first time this has happened on a steep, long grade on hot day. EGT's max at 1100. I have three questions:
1. What sender do you all use for the VDO water temp guage (part # if you got it).
2. Could a dirty injector cause this? Last time I pulled my glow plugs one was wet...and every once in a while I get an odd puff of black smoke... nothing serious but a small puff.
3. What else should I look at? I was going to clean the inter-cooler anyway but I doubt that is it. Coolant is new. Oil is new. Rad looks good but I have not had it flow tested.... there is one thing, The engine is mounted 2in back in the bay due to the previous 2.5NA engine mounts. So the fan does not sit in the shroud but slightly out of it... do you think it could be not pulling enough air? but it is happening at ~50mph. Could be the viscous unit... I was under the impression that at speed a fan would not be needed if everything was running correctly.
Thanks for your help guys... a hot tdi is an unhappy tdi.
Old September 3rd, 2006, 02:58 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
I wouldn't trust that stock guage. The thing thats odd is that your EGT's are great. No issue if they only hit 1100. That takes the suspicion off the injectors. I would be very surprised if something was wrong. A tdi will usually stay between 195 to 205 once warm. A little creaping is fine. I would replace the guage and the sender and then check again. If it is still hot, the most likely culprit is the radiator.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 3rd, 2006, 08:22 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
running 50 up a long hill in the mountains at an altitude of 6k-8k feet... hmmm, your radiator is too small for starters. You'd probably freak if you knew your true temps, instead of the false LR gauge reading you are getting now. Your truck is probably hitting the 230? mark. replace the gauge with a VDO with numbers. Just the sender isn't going to do it.
I have been dealing with the same issue for a year now. Great EGTs even less than yours, but temps in the 220?-240? range while driving up long mountain passes. In the process of having a dimpled 5 core radiator made.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old September 3rd, 2006, 11:52 AM
D90user's Avatar
D90user
steve
Buck- Thats what I was thinking, first things first that guage has to go.
Sheki- How much is that rad going to cost you?
Old September 3rd, 2006, 01:28 PM
sheki's Avatar
sheki
David Shechter
Contact Pendy, he's having it built.
tdi
Anti-theft on a Tdi? Chaucer Misc. Chit-Chat 17 March 27th, 2006 06:17 AM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
