Tdi Gangsta Lean? - Defender Source
Old June 4th, 2010, 10:16 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Tdi Gangsta Lean?
Out of curiousity, my Disco 200Tdi tilts back about 5-7 degrees. Is this normal? The reason I ask is that I constantly drag my e-brake drum on obstacles and raising the rear end of the drive train up to level it out could raise my e-brake drum about 2".
Semper Fi!
Old June 4th, 2010, 10:23 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If you search pirate under "cut time" you can see where I lifted mine and cut out the frame and replaced it with square tube. Just be aware of fan shroud clearance in the front and drive shaft angles in the back. I couldn't raise mine more than an inch before it hit the floor though. So I took off the drum and changed my mounts to gain almost 4in of ground clearance under the drum and 2in of ground clearance under the frame.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 4th, 2010, 10:29 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks, I've been considering doing the same thing with my crossmember as well - it's taking a beating. I was really just wondering is there was a "technical" reason why the motor leaned back.
Semper Fi!
Old June 4th, 2010, 10:33 AM
Jonathan your drivetrain is mounted using lots of non-rover parts and is probably in the wrong position altogether. It might be worth your while to get a proper defender lt77 gearbox and start over, using the proper floors and other bits. Rather than adding on more made-up stuff to the made-up stuff that is already there.
to do that you would be looking at: fan shroud, rad hoses, exhaust, welding new mounts on the frame for the engine, gearbox mounts that bolt to the chassis, and all the floor pieces.
I suppose you could start by getting the chassis side gearbox mounts off an LT77 4 cylinder disco.
hope that helps...
Old June 4th, 2010, 10:38 AM
Wolf Fabrication
Sterling Archer
'08 D3
Hmm.. Spend $0 to raise my drivetrain, or well over $1k to swap gearboxes and floors? Plus the time to pull the drivetrain? You and your crazy talk. Everything works just fine, so why change it?
Semper Fi!
Old June 4th, 2010, 10:52 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
hope that helps...
What past experiences do you have that make you think "Rover" is somehow better than, well, anything else? The more knowledgeable I get on vehicle design, the more evident it is just how batshit crazy the designers of this rig were.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 4th, 2010, 11:50 AM
Rover stuff is very well designed in its purest form (a 1959 SII), by the time the NAS Defenders came out they bastardized that design, adding crap etc. and it became more cobbled in nature.
Old June 4th, 2010, 02:35 PM
Well, I knew I was going to get flamed for those comments. What I really meant to say is that when I look at something that is cobbled together and causing issues due to its cobbled-ness, it can be nice to start over with everything they way it was intended to be set up. No matter the faults of the original design, there is something to be said for a vehicle that is set up using as many factory parts as possible, for ease of maintenance and replacement over time.
Dave, you know I like your rig and have a great deal of respect for the knowledge that you have gained from building and re-building it. And I do recognize that alot of the mods you have would be useful even in less built up vehicles. With all that said, i can certainly tell you that the factory setup is far better than what the *builder* of Jonathan's truck installed.
Sorry JG, not trying to bust on your rig. Even if you kept the Disco box I think you could do a better job than whoever installed that drivetrain.
I think it is instructional to see how the factory did things, that way you can be sure your mods are an improvement and not just going the long way around to achieve the same thing as the off-the shelf part.
I have alot of experience building my own stuff and working on stuff that others have modified as well. Not quite the same as the experience you have had, but certainly applicable. I've been around LR's a long time and I've seen common and uncommon failures on the road and on the trail. I never said that I thought that Rover was any kind of be all end all. In fact I've spent all of my 15 years of Rover ownership trying to make them better.
Old June 4th, 2010, 10:28 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
cruzin
cruzin lean with the gangsta sheen
tdi
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
96/97 Passat Wagon TDi pcarey Wanted 7 June 5th, 2004 03:05 AM
