Tdi fuel system question - Defender Source
Old January 5th, 2015, 07:12 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
The factory 200Tdi fuel system is plumbed
Tank pickup -> sedimenter (water separator) -> lift pump -> filter -> injection pump -> return
If I plumb it so that it runs:
Tank pickup -> Racor 120A -> lift pump -> injection pump -> return
Would you forsee any problems? Chances of the lift pump falling apart and damaging the injection pump?
(The Racor is a combination filter/water separator that works best on the vacuum side of a system, can also be used on pressure side but only up to 7psi... what does the lift pump put out?)
Old January 5th, 2015, 07:56 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
I've been running a Stanadyne setup I got from http://thedieselstore.com/. Lots of options and bolts to the stock location. 10mm hose fitting off the lift pump to eliminate a compression fitting and 3/8 Gates fuel hose. I'd keep a filter before the IP.
Old January 5th, 2015, 08:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Adam:
I would not plumb it:
With the filter on the suction side, it creates a restriction, especially when the filter has particulate trapped and becomes restricted, that will put extra stress on the lift pump and may cause premature unnecessary failure.
Also after a filter change, the pump will have to work extra hard to suck all the air out of the system which is easier to push than pull.
Think you would be better off running longer length lines or re-positioning the filter location, in order to mount the filter after the lift pump.
Hope this is helpful.
RDavisinVA
Old January 5th, 2015, 10:23 PM
transientmechanic
1972 SIII
Thanks Robert, it would not be difficult to plumb it for the filter to be in between the lift pump and inj pump. Do you know what pressure the lift pump puts out?
Also, considering the Racor 120 is a water separator, I could eliminate the pre-lift pump sedimenter yes?
I know that the water sep will not work as well after the pump because the water becomes emulsified in the fuel, but not sure if this is a real problem or a theoretical problem.
------ Follow up post added January 5th, 2015 10:24 PM ------
That stanadyne setup looks nice but wow its really big!
------ Follow up post added January 5th, 2015 10:27 PM ------
Andy do you have the part number for the fitting you used for the return line? (to convert the olive/compression fitting to regular fuel hose instead of the nylon)
Old January 5th, 2015, 10:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Adam:
When ever I buy a filter, the main considerations are:
1. the cost of replacement filter elements
2. the amount of trouble it takes to replace the filter element
The genuine or genuine style sedimenter is non-restrictive and does an excellent job to trap water and particulate and can be mounted on the suction side of the lift pump (a big plus).
The other big plus is that it does not have a filter element, just a drain, and can be disassembled for cleaning, so it costs nothing to use.
Am no expert on the Racor or Stanadyne setups, so can't offer any help there, but have been successful with the combination of the OEM fuel filter with a sedimenter.
Lots of people use the Racor or Stanadyne setups successfully (like Andy up in Boston).
I do know that most filter water trap combos are usually a fuel filter with a cavity at the bottom to hold trapped water. Too much water and the media gets wet and swells blocking fuel flow.
For this reason I have always used a separate sedimenter before the lift pump and a fuel filter afterwards.
Add a 12V diesel pump after the sedimenter and your fuel system becomes self priming and self bleeding.
Again, hope this helps.
RDavisinVA
Old January 5th, 2015, 11:04 PM
I have the stanadyne fm-100 as well. Fits perfectly in the stock location with no mods. 2 micron filters. Used in many oem installation. Toolless filter change. Can add heaters and bowls and many other options of desired.
Old January 5th, 2015, 11:20 PM
transientmechanic
1972 SIII
Thanks Robert - does anyone know of a part number or have a link to an OEM-style sedimenter? Most that I have come across have the filter incorporated.
Also, if anyone has the spec for output PSI for the Tdi lift pump that would be great.
Thanks all
Old January 6th, 2015, 01:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You can pick up sedimenters anywhere.
I build custom ones as well that you can find by searching sedimenter under for sale parts.
Good Luck Adam.
RDavisinVA
Old January 6th, 2015, 03:55 PM
From the workshop manual....
Fuel lift pump pressure .................................................. ... 42 - 55 kpa at 1800 rpm
Old January 6th, 2015, 04:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Roughly 6 to 8 PSI according to John,s good research.
RDavisinVA
Old January 6th, 2015, 04:59 PM
transientmechanic
1972 SIII
That is good data thanks John. Based on that spec I will be able to plumb the Racor in between the lift pump and inj pump without issues, aside from reduced water removal efficiency.
fuel, tdi
To TDI or not to TDI, that is the question neduro Defender Technical Discussions 22 March 12th, 2012 04:29 PM
Bleeding TDI Fuel System isleofbones Defender Technical Discussions 5 October 21st, 2010 04:47 AM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
LR Fuel System Conditioner Cyborg Defender Technical Discussions 7 October 22nd, 2006 09:03 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
