TDi fuel consumption - Page 2 - Defender Source
Old March 13th, 2016, 04:25 PM
Originally Posted by RBBailey View Post
I thought the star wheel gear is what he meant when he said he turned the "clockspring".
Yes and that does not affect maximum fueling.
Old March 13th, 2016, 04:27 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Diaphragm went CW 90*, star wheel CCW first time 4 clicks, than CW 1. Adjusted fuel pin down 1.25 turns. Everything marked and documented so I can go back! Have done 1 thing at a time to judge differences in "feel", but no empirical data. I do have a tall rack and currently 265/75/16MTR's about to be replaced with a set of 7.60^16 XZL
------ Follow up post added March 13th, 2016 04:30 PM ------
And I realised I never mentioned the rack originally!
Email is
Same place, new dogs.
Old March 13th, 2016, 04:38 PM
RBBailey
RBBailey
1965 IIa
From what I'm reading, both the diaphragm and star wheel are supposed to be turned clockwise from original point. If you mean you went back to center after 4 clicks CCW, then went CW 1 click, that would be the right way to do it. But if you mean you went 4 clicks CCW, then 1 click CW, you'd be 3 clicks CCW from center, the wrong direction. This would mean your pin and star wheel adjustments are mismatched.
All of my experience with Rovers tells me little bits make noticeable differences. a 1.2 and larger tires does make for a higher final gear. It isn't much, but it could be noticeable.
Project:
1965 IIa SWB
Old March 13th, 2016, 04:42 PM
Probably mostly the rack.
Old March 13th, 2016, 04:44 PM
From what I'm reading, both the diaphragm and star wheel are supposed to be turned clockwise from original point..
No. They do different things me you need understand what they are doing. This is probably not the right thread to get into it.
Old March 13th, 2016, 04:45 PM
Roverlab
Trevor Griffiths
Yes, you have it correct, I am 3 clicks ccw from my starting point . Easy enough to try 1 click CW from starting point!
Email is
Old March 13th, 2016, 04:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My 300Tdi gets a solid 22-23 mpg.
It was new in 2001, 160K miles now
1.2 LT230Q TC with a Zf4hp22 automatic
235/85R16 (31.5") I run 45psi.
Stock '97 diff's
Fuel screw turned down 1/8 turn (Clockwise) from factory, out of the crate setting (for elevation).
My elevation is 4500' + and hilly
I run a custom 198 T-stat. (Ford's run as high as 215 T-stats) I have run a 203 in the winter with no ill effects.
My only thought about the poor mileage you guys are seeing is a heavy, off the line, foot. Drive it like you have a raw egg between your foot & the accelerator & keep the RPM's <2500. I'd bet your mileage increase. And pay no attention to the jerk riding your A$$ off the line.
After all why did you buy a diesel anyway, it wasn't to "lay down rubber".
Old March 13th, 2016, 05:26 PM
Roverlab
Trevor Griffiths
True, was not expecting vw TDi fuel economy or blistering accelaration. It just seemed a little off, and I know Ive driven others that felt more crisp. More like I wanted to add to my knowledge base. More customers are asking, more are looking at legal imports, so I figured I could always learn something to help them, and help me.This car was a customer's, and I'm fortunate to know the history. Currently at158k.
Email is
Old March 13th, 2016, 05:44 PM
Roverlab
Trevor Griffiths
I should mention it's now mine....and I am neglecting my other Rovers while I fix all the detail stuff that had always bugged me when it was Tim's.
Email is
Old March 13th, 2016, 05:48 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My wife drives an '06 Liberty with a CRD 2.8 diesel. Now that thing JUMPS off the line like a gasser!
Her mileage is always less than when I drive it. I can consistently get 28-29 where as she gets 24-25.
The fly by wire cars have such a fast throttle response that it is easy to waste fuel.
Again, the raw egg and <2500 rpm rule will greatly influence your mileage.
Old March 13th, 2016, 06:20 PM
Roverlab
Trevor Griffiths
Gentle throttle makes sense, but initially, I was not getting a lot of throttle response, so foot to the floor until the boost came up was the rule, unless headed down hill.....
------ Follow up post added March 13th, 2016 06:21 PM ------
Any thoughts on the Timber Trail boost pin?
Email is
Old March 13th, 2016, 06:44 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Stock '97 diff's
Yep! That's what I was trying to say. I SHOULD not drag race the korean street rods!
may try rolling smoothly on a tank full (16 gallons in the D) and see what I get...
Old March 13th, 2016, 06:52 PM
RBBailey
RBBailey
1965 IIa
I found that in the Disco I actually got better mileage if I accelerated fairly quickly to whatever the speed limit was, then I basically coast with my foot just floating on the gas. This was due to the time taken to get to cruise speed being effectively cut in half, therefore using less fuel to get to that optimum cruise.
Use every down hill for acceleration, don't waste fuel trying to accelerate up hill. I could get 13.5mpg on the way to work if I concentrate. If I didn't, I would get 12mpg.
However, I suspect that driving a diesel is different in some ways. I'll have to relearn.
Project:
1965 IIa SWB
Old March 13th, 2016, 07:02 PM
azlandrover
stephen gross
1959 Landrover
Originally Posted by lrnasd90 View Post
The best I have ever gotten with a 300tdi is 19mpg. I have had 4 (3 of them where in d90s and one in a 110), so I guess they where all set up wrong? I often challenge the idea that they actually get the mpg numbers that I have read about. I suppose in a bone stock truck with road tires they may get that, but I have never actually observed it. None of my trucks where bone stock. All had lift kits and bigger tires. Now I did have a td5 (in a Defender 110 crew cab) and it did get 28mpg all the time. It had a lift and bigger tires.
I have a D110 with a 300 Tdi and consistently get 24MPG. Stock tires and no mods..
-sg
Old March 13th, 2016, 07:36 PM
IME, it does not matter a lot how you drive with a diesel. It makes a huge difference with a petrol. On the highway it does matter how fast you go.
Old March 13th, 2016, 07:58 PM
hcdmueller
Chris Mueller
88 D-90
I have been getting a consistent 20 with my D90. How I drive it definitely matters. Maybe not as much as a gasser, but full throttle acceleration and high cruising speeds definitely have a bad effect on my mileage. I regularly cruise at 80mph here in Phoenix. That is just keeping up with traffic. If I run it really hard, the mileage drops down into the mid teens.
Old March 13th, 2016, 08:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My last fill up was 20 MPG. That's city driving, running B50. My all time best is 28.3 MPG and my all time worst 13.9 MPG. I've been keeping a record for the past 7 years.
Old March 13th, 2016, 10:29 PM
In my experience trucks with turned up pumps produce considerably more torque and get better mileage because you aren't constantly flogging the engine.
Stock is extremely anemic, many don't even idle smoothly because they are set so lean.
With 235/85's I regularly got 22-24 in my 130. With 285 km2's that dropped into the high teens.
Stopped paying attention when I put 35's on it.
Old March 13th, 2016, 11:40 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
I have a 300 Tdi in a 110 CSW, closing in on 300,000 kms. Bit of a lift, bit of a tweak to the FIP, VNT turbo, 1.2 LT230Q, 235/85/16s. I agree that whether I am caning the beast in the fast lane or babying it, there is little impact on mileage IME. Winter weather seems to knock it down more. I get about 21 miles per US gallon. Had a nice tailwind the other day on the highway and managed 23 mpg.
Old March 14th, 2016, 12:01 AM
You do get less in winter because the winter fuel have less energy.
fuel, tdi
Left front skin, TD5 fuel filter, Fuel Pedal, mystery parts tomaco1 For Sale - Parts 12 August 24th, 2011 01:13 AM
300tdi No Fuel - Fuel Cutoff Solenoid Epsom_D2 Defender Technical Discussions 6 April 21st, 2011 01:42 PM
Fuel tank skid / fuel pump / Dixon-Bate Tow Jaw chris snell Smaller Projects 16 September 2nd, 2010 12:29 AM
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
