Tdi Fording Plug Size? - Defender Source
Old April 19th, 2010, 05:09 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Anyone know the fording plug thread size? I also have a threaded hole in my timing cover that looks to be the same.
Semper Fi!
Old April 19th, 2010, 05:18 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Metric.... Fine thread.... 12MM? Measure the hole ID
Keith
Big, Red and ... aaa Red..
Old April 19th, 2010, 05:21 PM
Wolf Fabrication
Sterling Archer
'08 D3
LOL, that's what I've done. Hoping someone had the definetive answer before I wandered the hardware store.
Semper Fi!
Old April 20th, 2010, 08:51 AM
1/4" bsp.
Old April 20th, 2010, 11:40 AM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
pretty sure it's 14mm w/ 1.5 pitch
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old April 20th, 2010, 01:19 PM
On the 300tdi they are 1/4 BSP same thread as the oil drain plug. I just ordered mine from RN, it was easy!
Old April 20th, 2010, 01:41 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Use NAPA #704-1361
A nice little drain plug with a plastic gasket. Works perfectly as a wading plug.
M14x1.5 if you want a bolt (but the NAPA plug is better)
Email:
Old April 20th, 2010, 02:20 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by ECR View Post
Use NAPA #704-1361
Awesome! I am heading to Napa this afternoon anyway. Cheers
Semper Fi!
Old April 20th, 2010, 07:48 PM
Wolf Fabrication
Sterling Archer
'08 D3
As a follow up, the Napa #704-1361 worked perfectly and is the correct thread size is indeed M14mmx1.5! Not sure where the 1/4bsp comes from, are they similar threads?
Semper Fi!
Old April 20th, 2010, 11:52 PM
If I recall correctly, 1/4 BSP was one thread per inch off of 1/4 NPT. I was able to use my 1/4 NPT tap to clean out the threads on the oil pan of my 300tdi.
thread pith of 1/4 bsp is 1.337mm, major diameter 13.157mm. So yeah it is conceivable that it would fit a short length of 14 x 1.5, and vice versa.
tdi
Glow Plug Issues- 300 Tdi Mark McDonough Defender Technical Discussions 2 July 9th, 2009 02:33 PM
200 TDI Exhaust Size 49COE Defender Technical Discussions 2 May 21st, 2009 09:32 AM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
