Tdi flywheel housing to block gasket - Defender Source
Old June 7th, 2013, 01:49 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Took the flywheel housing off my 200Tdi to fit it up with my Series 3 transmission. It has a high quality paper gasket between the flywheel housing and block... I called Rovers North to order a replacement but was told they rarely sell this part (special order).
Do most just seal them up with Right Stuff or what?
Also, it makes sense to replace the rear main seal while I'm here. Any tips?
Old June 7th, 2013, 01:58 PM
There's a seal? WTF?
Mark Kellgren
KM4BOR
Old June 7th, 2013, 02:07 PM
transientmechanic
1972 SIII
Err1440
Old June 7th, 2013, 05:47 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Why would you need a seal, the chamber where the clutch & P-plate are, it isn't watertight. Maybe, if the bell housing is AL, and since the block is FE, they are trying to minimize galvanic reaction of the 2 metals. Then there's the possibility of mating poorly machined surfaces.
Old June 7th, 2013, 08:44 PM
That gasket is very much needed that area is NOT dry on a 200tdi. Get the good one, not the cheap paper one. I got a nice one from RDS. People who advocate leaving that out are the same people that say you can leave out the four bolts on the bottom of the bellhousing. Big leaks will happen!
Genuine only on the rear main. I used real hylomar on the flyhweel housing gasket since I knew it it would be a while for the bottom four bolts to go in because of the way I was doing it. If I did it again I would just put the bolts in through the flywheel housing and not the trans bellhousing as I did.
RTFM...
Old June 8th, 2013, 11:05 AM
transientmechanic
1972 SIII
I definitely see the need for the gasket here on the 200tdi. Maybe not on a 300 that has the separate rear main seal.
To be clear this is between the flywheel housing and block, not between the bellhousing and flywheel housing.
I will order the good (Elring) gasket then, instead of right stuff
This is where the gasket goes
Old June 8th, 2013, 01:12 PM
pendy's Avatar
pendy
jim pendleton
89'd90
That is a good looking gasket. I always use sealer on 200 tdi. Yes it is important to seal on this engine.. I use a sealer called hondabond or yamaha bond. A motorcycle case type sealer for this application. The vibration is tough on the gasket in this application.
But that gasket you pictured seems up to the task.
legend in my own mind
Old June 8th, 2013, 04:13 PM
transientmechanic
1972 SIII
If hondabond works I'll skip the $50 for the gasket. Hondabond fixes everything
Old June 9th, 2013, 11:22 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I would use the thin type 4 on both surfaces, not the thicker version.
Old June 9th, 2013, 01:02 PM
File this under you learn something everyday.
Old November 22nd, 2013, 10:02 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Getting ready to fix this over the Thanksgiving weekend. Does anyone know if the pitch on the 4 M10 bolts for the bottom of the flywheel housing is 1.5 or 1.25? I'm think its 1.5 but not sure...
Old November 22nd, 2013, 11:07 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
1.5
I have some spares if you want them. I had to buy a box of 10 from McMaster Carr because I couldn't find them locally. I ran a tap through the holes to clean them up first.
Old November 22nd, 2013, 02:10 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Jeff, that would be great if you think you can get them sent soon so I'll have them next week. I'll send you a PM.
tdi
300 tdi water pump housing pendy For Sale - Parts 0 May 8th, 2013 02:32 PM
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
Coolant Heater - 300 TDi Block drain thread size Jackie Treehorn Defender Technical Discussions 11 December 17th, 2012 12:53 PM
Tdi block heater...anyone using? nathanwind Defender Technical Discussions 16 December 10th, 2012 03:22 PM
300 tdi short bell housing pendy For Sale - Parts 9 February 6th, 2009 11:22 AM
