TDI Bosch IP max fuel screw - Defender Source
Old September 18th, 2011, 08:59 PM
is the circled screw in my pictures the max screw? If so, can someone clarify exactly what it does? does it increase the fueling along the entire throttle range, or just at the top end? I have not had any luck on the web finding a picture of the screw, even though it is referenced quite a bit. I think I have everything else straightened out and in place to start tampering. I just need a little more juice on the highway and that's it. Seems to be beyond what I can get from the boost diaphragm.
ID:	42098   Click image for larger version
Old September 18th, 2011, 09:06 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Yes, this screw does change the fuel delivery quantity over the entire throttle range. You want to adjust it incrementally & slowly, 1/4 turn is a big change in the fuel quantity delivered. For more info on it look at some Dodge cummins sites, theres lots of good info there on fuel adjustments to the Bosch VE injector pumps.
Old September 18th, 2011, 09:09 PM
Thanks. as for the tamper collar, do you see it on mine? Don't want to go cutting the wrong thing.
Ok, I found a good link for illustration. Thanks Dennis
http://mopar.mopar1973man.com/cummin...p/inc-pump.htm
Old September 19th, 2011, 06:00 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Just get a screwdriver/small pliers into that tamper proof collar, lever it off and throw it. it's only where the pump was initially set up at the factory they then fit the collar for warranty issues.
Old September 19th, 2011, 10:11 AM
reb78
REB
Land Rover 110
I found that you could get adequate adjustment on that screw without removing the collar. I've turned mine about 165 degrees and it makes quite a difference. Bit more smoke, but not excessive.
This site has a fairly good description as well:
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Old September 19th, 2011, 10:14 AM
reb78
REB
Land Rover 110
The attached PDF is also handy for those 'tweaking' their pumps. It doesnt describe the adjustment of the fuel screw though.
tdi pump tuning.pdf
Old September 19th, 2011, 06:34 PM
Thanks all! I was able to knock that anti-tamper sleeve off very quickly with a flat head screwdriver! No other tool required.
bosch, fuel, tdi
Bleeding TDI Fuel System isleofbones Defender Technical Discussions 5 October 21st, 2010 04:47 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
