Tdi block heater...anyone using? - Defender Source
Old November 26th, 2012, 06:48 PM
A recent thread got me thinking about a block heater for the Tdi during the winter. I hate the lumpy starts in the cold weather.
So...what is everyone (anyone) using out there? Any suggestions?
Old November 26th, 2012, 07:06 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have them in both my 200s and they really help in the am.
I can look up the part # when I get to my computer.
Old November 26th, 2012, 07:38 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
I have a 1000W Zerostart heater combined with a Jabsco pump plumbed into the coolant system, both of those plugged into one end of an all-weather extension cord, all of this mounted onto the top of the LH front wheelarch. When I plug the other end of the extension cord in (I use a timer so that it turns on around 6 am), the heater starts up and the pump circulates the warming coolant around the block. An hour or two of that and the engine fires right up, even in -30C weather. Sort of an Eberspacher approach using mains electricity instead of the diesel fuel line. Works a treat, so long as you have an outlet to plug into!
Cheers,
Old November 26th, 2012, 08:21 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
This freeze plug heater fits the 300tdi exact!! KAT'S FROST PLUG #11441 I have one installed in mine.
Old November 26th, 2012, 08:38 PM
Maximal
Max
none
I've been going back and forth on the idea of a block heater. I don't really have a way to run a lead to my truck right now though because I live at an apartment complex.
Old November 26th, 2012, 09:02 PM
Seems like an easy fit to do...any feedback? Simple install? How well does it work? What temps have you started it at?
Found it here:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Old November 26th, 2012, 10:50 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Found it here:
Kat's builds a nice unit. Simple install, just punch the center freeze plug off center. This will kind of spin it or tip one side outward, then gently pry it out with a screw driver being careful not to nick the freeze plug hole (block). Be sure to mount it according to the directions, I think, "heater coil up". Works great I have mine on a timer so it's only on about 2 hours before I need to start it. I wrap the extension cord through my drivers door handle as to not forget to unplug it. I use mine when it gets below 20*F, otherwise the glow plugs work fine. I only have my glow plugs on in the winter, in the spring-summer-fall, I pull the fuse to them so they're off.
I'm experimenting with a hotter thermostat too. I "built" a 198*F thermostat and so far it's not running as hot as I'd like. Just put in the VDO Vision gauge and it's running at 175*F when it's open (verified with IR thermometer). I also have a 205*F thermostat I "built" but I want to see how the 198*F works out for now.
Old November 28th, 2012, 05:03 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Has anybody used the Napa ones that are just a heating pad on the oil pan and block?
In Alaska we used those with success along with battery warmers and trickle chargers...
Old November 28th, 2012, 05:09 PM
Yes. They heat the oil, which is good for the engine. You don't get any heat into the head, which is what helps starting.
Old November 28th, 2012, 11:01 PM
That's all I use. It's probably not needed, but I found a few new in the box at work and decided to use one. If anything it makes it crank a little quicker. I rarely use it since it doesn't get that cold here.
Old November 29th, 2012, 10:07 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
had an oil pan pad heater in the defender which seemed to help cold starting, have a block heater in the Disco (300tdi) now, makes a HUGE difference in cold starting. I may add a oil pan heater to this engine too. My problem seems to be fuel gelling more than starting however. After 5-10 min of running its ok but at first it doesn't really like going far above idle.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 29th, 2012, 10:32 AM
maybe its just me but I don't even need glows until temps get into the teens. Pretty sure I need injectors because it doesn't start after 1/2 a revolution anymore.
Old November 29th, 2012, 11:09 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Injectors I sell those
As far as a heater I use a in hose one from Napa. I have a factory freeze plug block heater sitting on the passenger floor waiting to be installed.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old November 29th, 2012, 11:47 AM
Michael
Michael
Discovery 1998
Have been using a diesel fired espar since 2006, i think it is D5s. Nice unit so far. Sounds like truck is going to take off when it fires up.
Old December 10th, 2012, 02:32 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Has anyone tried wiring a block heater into a dual battery system? maybe with a cutoff override. I know that may sound silly but if youre in a remote area with no direct ac to plug into...so maybe an inverter set up? Just curious whats been done. I've searched and read various threads but nothing really applies.
Old December 10th, 2012, 02:53 PM
most plugin heaters are in the 1500 watt range which would suck a battery dry in no time. remember when its very cold, your battery can be reduced to 50% capacity at a full charge til it warms up. you'd need a big inverter to do this but it could easily leave you stranded. better to by a little portable gen than take this approach if your remote and dont want to invest in webasto.
Mark Kellgren
KM4BOR
Old December 10th, 2012, 03:22 PM
Bill Larson
Bill Larson
good point.
heater, tdi
300 TDI Block Heater Part # brn24whl Defender Technical Discussions 27 February 25th, 2017 10:55 PM
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
Tdi AC and heater ductwork artm Defender Technical Discussions 7 February 13th, 2007 07:41 PM
Engine Block Heater for Defender 110 - tips? COSteve Defender Technical Discussions 10 December 6th, 2005 01:12 PM
