TDI block drain plug washer orientation - Defender Source
Old May 14th, 2016, 07:51 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Can't find the info on this in the manuals so I thought I'd ask here.
On a 300 TDI the block located coolant drain plug has a profiled copper crush washer. Which way should the washer be oriented in relation to the bolt? Or does it matter?
Two ways washer could be installed illustrated below.
Old May 14th, 2016, 10:42 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I don't think it matters as long as you get the proper Torque on it.
Old May 15th, 2016, 01:31 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The block plug on my '01 engine is on the manifold side of the block and is like a taper threaded, square headed NPT pipe plug.
Old October 18th, 2016, 08:19 AM
Sumi
F. András
1994 Def 110 SW 300Tdi
Hi! Does anyone happen to know the torque setting for this bolt? Can't find it on the net
Thanks!
drain, drain plug, tdi
Wanted thread size wanted on 300 tdi drain plug? Greenbull Defender Technical Discussions 1 March 23rd, 2016 02:38 PM
Coolant Heater - 300 TDi Block drain thread size Jackie Treehorn Defender Technical Discussions 11 December 17th, 2012 11:53 AM
300 Tdi decanter weak drain plug JFD Defender Technical Discussions 11 July 20th, 2011 10:43 AM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 02:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 08:02 AM
