TDI alternator failure?? - Defender Source
Old March 4th, 2015, 09:41 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
So I left work a little early today to try to beat the incoming snow/sleet event. Truck started up just fine, but about half way home I noticed the battery light was on. The battery has been a little soft with the cold weather and I've had to jump the truck a few times (glow plugs aren't hooked up), but the battery light always goes off shortly after starting. A few minutes later the windshield wipers started going slower and slower, then the fan stopped blowing air. By this time the roads were getting bad so I pressed on, but sure enough the truck died. Luckily I was able to coast to a turn lane so wasn't blocking traffic. Sounds like alternator but it's been running fine so I was surprised that it happened so quickly. Someone stopped to help and we jumped the truck with all accessories off (lights, heater fan, wipers) and I was able to drive home. As I was driving the battery light was slowly fading as if the battery was charging, so still not sure what the issue is. Any thoughts?
Old March 4th, 2015, 09:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Break in the field wire.
RDavisinVA
Old March 4th, 2015, 09:55 PM
You need to test things to see if it is the battery or the alternator.
Old March 4th, 2015, 10:04 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Robert, forgive my ignorance but whats the field wire?
Old March 4th, 2015, 10:15 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Smallest wire on the alternator.
Usually brown with yellow or the other way around.
It runs from the F alternator terminal to the ignition warning light.
RDavisinVA
Old March 4th, 2015, 10:16 PM
Smallest wire on the alternator. Usually brown with yellow or the other way around. It runs from the F alternator terminal to the ignition warning light.
If it was broken the dash light would not come on. The light grounds through that wire. Q
Old March 4th, 2015, 10:37 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
What doesn't make sense to me was that I was able to jump it and drive it again. If it was the alternator, would that be possible? What's the best way to test the alternator?
Old March 4th, 2015, 10:41 PM
The first thing to do is see the voltage with the engine off and running. If the battery is bad it can be hard to determine which is the problem.
Beyond that you need a battery load tester or an alternator tester.
Old March 4th, 2015, 10:43 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
You didn't say what was on after the jump. All a TDI needs to keep running is the fuel solenoid to stay open, which is a very simple circuit with almost no power draw. Even with a crap alternator on the way out it may be enough to get you home.
Did you keep the lights or heater fan on? Those are your largest electrical draws on a Tdi.
Old March 4th, 2015, 11:29 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I said in the original post that I turned off all accessories (lights, wipers, fan) after we jumped it. I've got another battery so I can try that tomorrow. Just don't want to drain another one if it's the alternator.
Old March 4th, 2015, 11:49 PM
With a good known and charged battery you should see 12.5 volts or so engine off. Running the voltage should come up to 13.5 at least when reved up.
If the voltage comes up and the light still flickers you have a bad rectifier.
If it does not and you have the type with the brushed and regulator that are bolted to the back, pull it off and check that the brushes are not stuck.
Old March 4th, 2015, 11:59 PM
Ignotus
gene
1960 109, w/200TDI
Some of the chain auto stores will check your battery and alternator for free. Take em off and take em in.
Gene
1960 109
1960 88 Ignotus
Blog;
Old March 5th, 2015, 12:04 AM
Meh. Learn to test yourself and you are one more step to independence.
Old March 5th, 2015, 01:36 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I've never been good with electrical stuff but it turns out this is a mechanical problem.. The belt is gone! Thanks for the input guys.
Old March 5th, 2015, 01:48 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Nice!
RDavisinVA
Old March 5th, 2015, 01:51 PM
I don't care who you are, that's just funny!
Next up, "My truck won't start. The gas gauge shows empty, the low fuel light is on, could it be the tire pressure?"
I'm glad you sorted out your issue.
Old March 5th, 2015, 02:00 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
😊. I admit that I posted before I was able to look under the hood. I couldn't make it all the way to the house since I live on a steep hill and wasn't up for diagnosing the problem in the midst of the storm when I knew I could look at it today. I really am more competent than this makes me sound!
Old March 5th, 2015, 02:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It's OK.
RDavisinVA
Old March 8th, 2015, 10:48 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Put the new belt on and the PS pump started squealing, mist likely the cause of failure. It stopped after a minute but looks like I'll need a new one. Anyone have a disco 200 TDI PS pump laying around?
Old March 8th, 2015, 11:45 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Mike - I do. This is what I have. Check to be sure it is what you need.
NTC8287 - Pump 2500 cc - L/R - 4 Cylinder - Diesel - TDi - Turbo - 11L - 200 TD
New (installed but never ran) - Retail $152 - I would take $100 + shipping.
http://www.paddockspares.com/ntc8287...11l22454a.html
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
alternator, tdi
Alternator failure in Main Rocky Defender Technical Discussions 8 February 12th, 2015 11:20 PM
Alternator Failure. ajh Defender Technical Discussions 2 February 9th, 2011 09:58 AM
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
300 Tdi Serpentine belt failure roverboy Defender Technical Discussions 5 May 25th, 2006 02:53 PM
Tailight failure rustydefender Defender Technical Discussions 9 August 15th, 2005 01:23 PM
