Tdi alternator - Defender Source
Old January 7th, 2011, 10:43 AM
Tdi alternator
I have had no joy with the Italian Magni Marelli products.
Last summer my alternator started to growl- ie bearing noise. I was offered a 100 amp alternator from a 300 disco so I bought that and installed it. Last weekend that alternator burned up litterally-smoke billowing out from under the hood. I looked around and found that Denso (Japanese brand) offered a 100 amp unit for this fitment ( I saw this as an upgrade in quality). So I ordered it Tuesday from Paddocks. Ups man just dropped it on the porch a few minutes ago (faster than from Vermont). I open the box and the outer package says denso and I open it up and it looks like another frigging Marrelli. I flip it over and it says made in Italy and the plastic on the back has Magni Marelli cast into it. PI$$ED
Old January 7th, 2011, 10:51 AM
bjf's Avatar
bjf
barry f
94 ST #395
What comes direct from land rover?
Old January 7th, 2011, 11:03 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If its in a denso box, it was raised in japan and thinks its a denso, dont tell it the truth and it should lead a longer, happier life.
Old January 7th, 2011, 11:14 AM
When Japan starts outsourcing electronics to Italy, I know the new world order is emerging! Question is, what will it mean for us all?
I'm pretty sure that my 2.8 alternator is a Bosch. Reason I dont' have a 300tdi alternator is due to the vacuum pump bolted on the back. Pendy told me that I could switch to a 300 tdi alternator (without vaccum pump) if I put a tdi vaccum pump on the block per LR factory. What I'm inferring from this is that if my Bosch fits on a 2.8, it'll fit on a 300 tdi, since the castings and mounts are all the same. The only thing is, it's not 100 amp. it's 80 or 60 (can't remember which right now).
Old January 7th, 2011, 11:32 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I believe Magnetti Marelli is an oem for the D90. I also believe they are a distributor for Denso so it may be very possible that Denso did in fact make the alternator or some of it's components. I don't know who makes the Pro Line. You can always have your alternator rebuilt at a local shop and have it's output increased.
Old January 7th, 2011, 11:51 AM
i know a serp belt alternator from a v8 will fit if you cut one of the ears off. maybe you can find a cheapie @ crazy ray's. but it will still be the same MM crap. you could get a rebuilt from your FLAPS just make sure you get one with a good warranty. Actually scratch that they won't likely take it back with an ear sawn off the back...then again they might not notice if you do a nice clean job of it....
Old January 7th, 2011, 01:07 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Should have bought a bosch from me.
legend in my own mind
Old January 7th, 2011, 01:20 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
I rhave a 100 amp ex UK supplier. However, when I compare it with the one fitted to my Disco 300tdi (in the D90) the end cover is plastic. The original is a cast end cover with a steel heat shield.
I'm concerned about mounting the new one as the plastic cover is fairly close to the turbo.
Any thoughts?
Old January 7th, 2011, 01:36 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
how much have you paid for that Denso / magneti ?
Old January 7th, 2011, 01:41 PM
Interesting point, Doug, do you have the heat shield on yours?
Any thoughts?
Old January 7th, 2011, 02:13 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
I have a Denso and a Magnetti Mareli alt at home, and I swear that other than the name sticker they are the same.
Old January 7th, 2011, 02:58 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check old threads, you can get an 100 amps Iskra for less than 200$, just have to do a pulley swap.
- Charles Eames
alternator, tdi
300 TDI Alternator AMR4249 65 amp brn24whl The Vendors Loft 20 August 19th, 2011 02:49 PM
100 Amp TDI Alternator - New Red90 For Sale - Parts 1 September 24th, 2010 09:09 AM
300 tdi alternator tmore Defender Technical Discussions 3 September 10th, 2006 08:47 PM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
