Td5 wiring loom with 300tdi - Defender Source
Old August 31st, 2013, 06:27 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
Td5 looms seem to be all over the place where as the 300tdi ones are not is there any reason the engine, chassis, and bulkhead looms for td5 won't work for a truck powered with 300tdi engine?
Old August 31st, 2013, 08:17 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
I'm no mechanic but td5 are computer driven and 300 are mechanical so td5 harness would be way over complicated. I'd assume very little wires would work as intended.
Defender 110
Old August 31st, 2013, 10:18 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
There isn't much to the 300tdi harness, and really you're better off to make your own if you're going to do popular upgrades such as VDO gauges or higher output alternator. Very very simple stuff for the 300tdi. But if you're after genuine, then I understand your preference.
Old August 31st, 2013, 10:32 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I used a 1999 td5 for a 200tdi. Lots of extra stuff, but it works just fine.
Old August 31st, 2013, 10:54 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
just buy one from autosparks...
Old September 1st, 2013, 12:07 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
If I'm not mistaken they only offer the 200tdi loom is it the same?
Late td5 dash wiring cabell Defender Technical Discussions 43 May 18th, 2013 08:22 AM
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
td5 fuel tank into a 300tdi chassis Muscat Defender Technical Discussions 7 April 4th, 2008 06:02 PM
ARB M002 Heavy Duty Wiring Loom Troys Defender Technical Discussions 1 December 15th, 2006 03:55 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
