TD5 - what parts to keep on hand? - Defender Source
Old January 29th, 2013, 08:19 PM
gomotomoto
adam
What parts would be smart to keep around for your TD5's?
Old January 29th, 2013, 08:31 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Belts and hoses would be on the list as they would be harder to source if you need one right away.
Land Rover 110
Old January 30th, 2013, 02:45 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
MAF (Air flow meter.... clips onto the air box) and a crank position sensor (bolts onto the bellhousing just under the air box)
a duff MAF will cause a bit (not much) smoke and less performance.
CPS will stop the engine dead. That's the only sensor that will stop the Td5... all the rest will revert to a default setting in the ECU, so performance might be a bit down, but at least you'll get home.
Neither of the above need a nanocom/NASA computer to fit, just plug & play.
Old January 30th, 2013, 09:49 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Jamie is right on - as usual. The only other bit I have in my spares box is an accelerator pedal. If it fails, the truck will idle, but you won't be able to rev.
LRseries.com is where I get my TD5 bits.
HTH.
Old January 30th, 2013, 10:02 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You are too kind sir
HTH.
Bear in mind there are 2 types of throttle pedal available (or "driver demand unit" as they're officially called )
there is a 2 track, and a 3 track (referring to the number of potentiometer "tracks" inside the pedal). with the aid of a nanocom etc, you can easily change in the ECU settings as to what one you have.
now i'm not 100% if an early ECU, which would have been built with a 2 track, can be switched to 3 track, but the later 3 track era ECU's can certainly be switched back to the older type of pedal.
If you plug a 3track into an ECU that's set for 2 track, or vica versa....
I dunno.... never tried it. will have a play (have one of each vehicle here)
Old January 30th, 2013, 11:00 AM
gomotomoto
adam
How about injectors?
Old January 30th, 2013, 11:15 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Nah, they're pretty reliable. (OK, if you come across one/some then handy to keep spare)
Apparently they were designed along the lines of truck technology for uber mileage. One doesn't usually hear of any problems with them (although the copper washer at the tip, and the O ring that keeps the diesel out of the sump can fail... pence to buy but a little fiddly to change)
Injectors are uindividually coded. These are set in the ECU via nanocom/testbook etc. The engine will run with an incorrect code (you may not even notice) but won't be working to its full capabilities. again, minutes to alter in the ECU.
Alarm 10AS unit can go duff sometimes. they're cheap enough to keep a spare. this WILL need coding with the main ECU for the engine to start. again, takes seconds with a nanocom type thing.
Old January 30th, 2013, 06:48 PM
gomotomoto
adam
Where do you purchase your td5 parts? Is there a one stop shop? Maybe a reliable parts retailer online?
Old January 30th, 2013, 06:54 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Based on your location I would buy from rimmerbros. Please check you pm's
Old January 30th, 2013, 07:29 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
If you don't mind, please pm me the sources, as well. I've got a smooth running TD5, but would like to stock a few needed parts.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old January 30th, 2013, 07:37 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Shoot me an email with any TD5 parts you'd like to get.
info@safarihp.com
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Old January 30th, 2013, 07:45 PM
gomotomoto
adam
Will do. Any update on the 110 dcpu cage I asked about?
info@safarihp.com
Old January 30th, 2013, 08:12 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
info@safarihp.com
Sweet, will do. I'm going to do a little research on what I need, and I'll email you. I see you're in Orlando.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
part, parts, td5
D90 and Series Parts for sale rrubino2 For Sale - Parts 20 January 26th, 2005 05:31 PM
97 d90 LH drive parts steved90 Defender Technical Discussions 4 January 16th, 2005 08:23 AM
Parts Manual Kimos Defender Technical Discussions 38 December 9th, 2004 06:09 PM
hand winch questions chirider Defender Technical Discussions 8 November 28th, 2004 10:57 AM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
