TD5 temp guage moves with accelerator. - Defender Source
Old December 7th, 2014, 06:19 PM
Ttuck3r's Avatar
Ttuck3r
Tommy
1999 Defender TD5
Hello all, this morning on my way to work I noticed my temp gauge was moving to the input of the accelerator, if i revved her the needle moves instantly down to the cold end and as the Rev stabilises ( to idle ) the needle returns to proper operation position. I will be posting a video, can anyone shed some light please.
Old December 9th, 2014, 08:48 PM
barjout
Marc Bourget
1996/Tdi DEFENDER 110
I had the same issue on my 1996 Tdi. I didn't spent too much time troubleshooting and I was under the impression it would be a ground issue. So I replace the gauge and sensor and the wire between the sensor and gauge and it all good since then. I bought a gauge from www.mcnallyelectronics.com and now I can monitor both water temp and voltage from one gauge. I also had Mcnally's gauge with boost/EGT so I knew I was getting quality gauges.
2 guage and 4 guage pod for sale CDeWan For Sale - Parts 4 August 2nd, 2014 11:03 PM
Defender TD5 Accelerator Pin-out madcowdungbeetle Defender Technical Discussions 3 January 27th, 2014 02:03 PM
Defender TD5 Accelerator Pedal and Potentiometer Assembly rayfi For Sale - Parts 27 July 1st, 2013 09:22 AM
front end moves jimmy salmon Defender Technical Discussions 20 September 18th, 2005 04:40 PM
aftermarket temp guage options draaronr Defender Technical Discussions 7 January 4th, 2005 02:33 PM
