TD5 starting problem related to fuel level - Defender Source
Old March 5th, 2016, 03:53 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Hi all,
I have a 2000 defender td5 having the following problem. When its full, no problem what so ever, perfect starting cold and hot and runs like a breeze. But, whenever the fuel level is less than full it becomes difficult to get it started, and when its around 1/4 its almost impossible to start. Removed the fuel pump and and looked for any crack in the hoses, didn't find any.
Any one familiar with such a problem or suggestions?
Omar
Old March 5th, 2016, 03:56 PM
Tank vent working?
Old March 5th, 2016, 04:02 PM
Omero's Avatar
Omero
Omar Alomar
Originally Posted by Red90 View Post
Tank vent working?
Actually, when remved the tank found that the vent was disconnected. How to test it?
Old March 5th, 2016, 07:17 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Has the fuel pump been whining and it really no longer does. Also you should test the fuel pump with a test light. Read up on this http://forums.lr4x4.com/index.php?showtopic=54796
Old March 6th, 2016, 01:58 AM
Omero's Avatar
Omero
Omar Alomar
Originally Posted by tjfslaughter View Post
Has the fuel pump been whining and it really no longer does. Also you should test the fuel pump with a test light. Read up on this TD5 Disco Fuel pump/sender unit - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
only whining when fuel is less than full, sounds like air cavitation. When full no whining at all and works perfectly.
Old March 6th, 2016, 07:56 PM
tjfslaughter
thomas
Burbon
Do you know when the pump was last changed?
Old March 7th, 2016, 08:29 PM
jabber
m j
110
There's an insert within the fuel filter, to purge air from the line. Try running the normal fuel maintenance before you start it a few times.... Turn ignition to position II, step on the pedal five times. The td5 should go into a maintenance mode and purge the air. You'll hear a gurgling from the filter area.
If it starts consistently after the above, you'll need to change the insert in the fuel line... It's on the backside of the fuel filter housing.
I'd it still doesn't work, change the fuel pump.
fuel, start, starting, td5
Fuel level sender diesel wiring diagram anfonee1 Defender Technical Discussions 4 March 11th, 2014 04:49 PM
Defender 3rd Brake Light XFG100330 TD5-TDCI HIGH LEVEL Ben01 For Sale - Parts 1 July 13th, 2013 11:14 PM
Cold starting problem td5 pkneale Defender Technical Discussions 20 March 21st, 2012 10:56 PM
0460 Fuel Level Sensor GYM Defender Technical Discussions 0 December 2nd, 2009 05:08 PM
D90 starting issues - could it be Snorkel related? pmd Defender Technical Discussions 7 January 9th, 2009 12:47 PM
