Td5 Slave Cylinder location....right or left? - Defender Source
Old October 17th, 2016, 12:28 PM
Question Td5 Slave Cylinder location....right or left?
Can anyone confirm on a Td5 / R380 combo if the Slave Cylinder is located on the rightside or leftside of the motor [or technically bellhousing] (as you sit in the vehicle)?
I know with a NAS 3.9 V8 / R380 combo it's on the left, standard R380 on the right, and R380-stumpy it's on the left.
I'm 99% that on a Td5/R380 it's on the leftside now based on some pics I've seen...but want to make that 100% .
Old October 17th, 2016, 12:32 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
might find out here
INDEX.* Read this Post before looking at any threads* - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
Old October 17th, 2016, 09:06 PM
Bueller? Pretty sure based on some bellhousing pics I've seen it's left-side, but if anyone has any insight or knows for sure....
Old October 17th, 2016, 09:17 PM
I'll drive down the hill and look in the morning if you think its on the left.
Old October 18th, 2016, 11:21 AM
Here's a generic pic I found of what *should* be a Td5 bellhousing...made some notes on it which helps lead me to believe SC is on the left-side.
However, if anyone gets a chance to "confirm" with eyes-on would be muchas gracias .
Name:	Td5 Bellhousing.jpg
Old October 18th, 2016, 11:22 AM
tjfslaughter
thomas
Burbon
Can't you just call Ashcroft?
Old October 18th, 2016, 11:24 AM
Probably could, but figured that Clavin (Briggs) would be able to whip out this "little-known fact" in short order....
Old October 18th, 2016, 08:14 PM
eyes on answer is its on left side way back on bellhousing as per your picture
Old October 18th, 2016, 09:10 PM
You ROCK! Thanks Doug, much appreciated....
ht, slave, td5
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
clutch slave cylinder. CavemanDiesel Defender Technical Discussions 4 December 27th, 2012 10:39 AM
Clutch slave cylinder new in box for defender jonathon For Sale - Parts 2 December 3rd, 2012 10:42 PM
slave cylinder question jayz Defender Technical Discussions 0 March 30th, 2012 12:56 AM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
