TD5+ rear shocks on TDI - Defender Source
Old May 9th, 2015, 10:32 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'm sure this is covered somewhere, but I can't seem to find the info so here goes:
I've got a set of the NTO newer gas type shocks, the ones you would find on TD5 and TDCI's
that I plan to install on my 110 300tdi.
I understand that the newer rear axles have a set of cups welded to shock mounting area which replaces two of the four floating cups that have been used on earlier trucks.
The rubber bushings also look different, and I understand the threaded ends on the shocks themselves are longer
So my question is this; what's the best way to mount these newer shocks to the older axle? Can I use the new bushings? Should I just add a set of cups? Or is it best to use a set of the older bushings/cups and add a spacer to accommodate the longer shock end?
Old May 13th, 2015, 12:26 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Does anyone have a TD5 or TDCI rear axle that they could photograph the shock mounting points? I would like to see what the profile of the new interface looks like. Maybe I can make my own washers to match up with these new bushings.
Thanks!
td5, tdi
300 TDI / TD5 Engine Acustic Covers FS SafariHP The Vendors Loft 2 January 10th, 2011 07:57 PM
Elite 300 Tdi / Td5 AC Kits LHD or RHD SafariHP The Vendors Loft 0 October 28th, 2010 10:37 PM
Koni Heavy Track Shocks +2 - Land Rover - 4 New Shocks JohnC The Vendors Loft 7 April 13th, 2010 09:34 AM
TDI/TD5 question disco dog Misc. Chit-Chat 5 April 10th, 2009 06:20 PM
Early TD5 Steering Wheel, Indicator stalk complete, Td5 Harness FS SafariHP The Vendors Loft 0 January 26th, 2009 08:02 PM
