TD5 radiator expansion tank mounting bracket pics needed - Defender Source
Old January 3rd, 2016, 03:24 PM
Landy_Andy's Avatar
Landy_Andy
Andy
For my Gen III conversion I'm looking to use a TD5 radiator expansion tank as it sits high on the bulkhead and with the new heater sitting a bit higher than the stock one it should help prevent air being trapped in it.... that's the theory anyway....
To install I need to make a mounting bracket to bolt to the bulkhead, has anyone got a TD5 bulkhead they could snap a few pic's of the welded on bracket & post for me.
ac, bracket, mount, rack, radiator, td5
Expansion tank cap Mpigapicha Defender Technical Discussions 3 May 1st, 2012 08:26 PM
Expansion tank bleed hose trybul Defender Technical Discussions 0 December 5th, 2011 02:26 PM
Coolant expansion tank '01 disco genie90 Wanted 6 May 10th, 2011 05:44 PM
Coolant expansion tank '01 disco genie90 Wanted 0 May 10th, 2011 07:45 AM
Expansion tank leaking.. D90user Defender Technical Discussions 5 April 3rd, 2007 12:23 AM
