TD5 Intermittent Sputter - Defender Source
Old February 17th, 2013, 05:23 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
While driving my truck a few weeks ago in the icy cold, I was pulling into a gas station and noticed my TD5 running a little rough, and sputtering. Coming to idle, it sputtered like a blown head gasket feels/sounds, so I cut the engine off. When I came back out and cranked it back up, the sputter was gone, and the engine was running as smooth as normal. It's been a few weeks since, without a sputter.... But today I took it up to the mountains to fly fish, and when I left my house, it started to sputter about 5-10 minutes into the drive. It continues to run, albeit rough, and has a loss of power under load. If I come to a stop and idle, it runs rough.... However, all I have to do is shut the engine off, fire it back up, and it's back to normal idle immediately. It was fine all the 65-70 miles on the way up, but on the way home, it had a couple of sputtering moments. Again, I turned on/off.... Problem fixed until it decided to act up again.
One thing to consider.... My fuel pump is a bit louder at times than others. It's fairly loud once in a while. My fuel filter was replaced not long ago, and I keep the fuel tank at least half full almost all of the time.
Seems electronic to me (TPS?)..... Or the fuel pump is going. Just remember, the turning off and recranking corrects it every time... So far.
Thoughts?
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 05:48 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Order a pump. It's on the way out.
Old February 17th, 2013, 05:50 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
That's what my initial thought was as well.
Old February 17th, 2013, 05:54 PM
winn442's Avatar
winn442
Winn Bearden
it be the pump
Winn Bearden
Kelbo's Avatar
Kelbo
Kelly
'86 110
My thoughts, too. What is the reason for it resetting on restart? Is that normal?
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 05:58 PM
tjfslaughter
thomas
Burbon
The pump change is easy. Takes about 1.5 hours. A guy in Miami usually has them in stock. There is a test procedure to see if it fails. Drop tank, leave plugged in (two wires going to tank), ground a test light and probe the white wire. If it is lit up after you turn the key it is toast.
------ Follow up post added February 17th, 2013 05:59 PM ------
http://forums.lr4x4.com/index.php?showtopic=54796.
Make sure make a chart for the location of the 4 wires (color coded).
Old February 17th, 2013, 06:04 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Great. Who is the guy in Miami? This will be a new one for me, but I may try this job myself. Any special tools needed, other than ratchets? Things to look out for?
Thanks!!
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 06:10 PM
tjfslaughter
thomas
Burbon
Check ebay
When it goes try to have an empty tank, the trick is moving the skid plate out with out letting the tank fall and possibly break a fuel line. Use a floor jack to lower the tank incrementally. Ad look at the color coded lines and draw a picture. To remove the lines you just need to squeeze the plastic and pull. It is fairly simple.
Once you install the new pump add a pick up tube for a future webasto install if that is something you think you might want down the road. PM me your number if you want to discuss..
Old February 17th, 2013, 07:12 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
I just ordered on from safari HP and they had one. You might give them a ring to get one the are open tomorrow I think.
Old February 17th, 2013, 07:36 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
I appreciate it, Shawn. Was yours acting up, or just preventative maintenance?
I know this is a disco and I will have to drop my tank, but is this tech article spot on?
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 07:56 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
check the injector harness plug for oil ingress right front of head .....
No Mall crawler here
Old February 17th, 2013, 08:14 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
What Chris said. Prudent before diving into a fuel pump.
Old February 17th, 2013, 08:24 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Will do.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 08:43 PM
discotdi
Todd Miller
Land Rover
What he said.
Old February 17th, 2013, 09:21 PM
Will do.
Where exactly is it located? I know what to look for when I get there.
google oil ingress td5 wiring harness
Old February 17th, 2013, 10:20 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
The culprit has been identified:
I knew it, the moment I was reaching to unplug it and saw oily residue/dust on the outside of the plug.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 17th, 2013, 10:52 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Buy replacement harness. Easy job. Cleanup ECU and harness with electrical cleaner.
Old February 17th, 2013, 11:07 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Yep... Injector harness only, correct? I understand after the initial ECU plug cleanup, I'll have to clean it a few more times until all of the oil in the ECU harness passes through.
Although I prefer no issues (utopian dream), I'm going to do these kinds of things myself and learn my truck. Looking forward to it....
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old February 18th, 2013, 12:16 AM
discotdi
Todd Miller
Land Rover
I think there is a permanent "fix". Check Land Rover Owner mag.
Old February 18th, 2013, 12:49 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Yep, just the injector harness. IIRC, pull the engine cover, pull the head cover, remove existing harness and put back together. 30 minute job. Then clean the harness under passenger seat, connector, ECU. After a couple cleanings you should be trouble free. Glad to hear it was something simple.
td5
TD5 Rear door? dmarchand Defender Technical Discussions 28 April 13th, 2011 05:35 PM
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
TD5 trucks to the USA Trek Jon Misc. Chit-Chat 15 August 31st, 2005 03:42 PM
TD5 versus 2.8L PS jaherring Defender Technical Discussions 12 April 21st, 2005 05:49 AM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
