TD5 Hazard Wiring - Defender Source
Join the Defender Source Community Today
Old December 21st, 2014, 09:07 PM
BlackField's Avatar
BlackField
Oscar
D110
TD5 Hazard Wiring
Hello I have a YUG000180LNF TD5 hazard switch that I need to wire in.
looks like this:
I've temporarily placed the spade connectors directly to the switch ( i have the connector for when I have all the needed wires figured out).
Here is what I'm using as a reference:
and these two also:
here is where I'm stuck: 1,2,8
1 ?
2 ?
3 LG from relay
4 Dimmer switch (using a freelander switch)
5 ground
6 LGN from relay
7 GR from under the dash probably ties to the signal stalk
8 ?
9 GW from under the dash probably ties to the signal stalk
0 not used
My Questions:
- What goes to 1 & 2? I'm assuming some kind of fused +
- Where does 8 go? a remote flashing light somewhere? back to the dash?
- Did I get the other ones correct?
Thank you,
Oscar
Old December 22nd, 2014, 07:04 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
On my 95 NAS this is how I wired mine. Colors are the existing harness, numbers are the inputs for the new plug
1 black
2 red and white/red
3 light green
4 2 purple
5 white/green
6 n/a
7 2 dark greens
8 black/red that goes to your binical warning light
9 green/brown
10 green/red
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 22nd, 2014, 10:44 AM
BlackField's Avatar
BlackField
Oscar
D110
Thanks Paul,
I pulled up the NAS 90 wiring to help me understand what you did and it was helpful to compare the two.
Looks like you have live + on 4 and Ignition + on 7
It looks like I will need them in 1 & 2 since 7 is on the switched path on my switch.
1. IGN +
2. Live +
8. Does your Truck have a separate hazard warning light or does it flash the turn indicator lights on the dash?
Does your Hazard Switch Flash while its in operation?
Thanks again
Oscar
Old December 22nd, 2014, 09:01 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
the green white wires are switched power. you can get this from the fuse box or the old switch. A purple wire indicates a constant power feed. The 8 wire I think should go to the haz warn light. Some of the trucks have a separate warning light while the older trucks use the turn signal indicators.
Old December 22nd, 2014, 10:41 PM
lordhelemt's Avatar
lordhelemt
Paul
Oscar,
I'll look for my notes and will let you know what all the wires do, at least for a 95 NAS. Yes the switch as well as the left and right indicators on the binical flash when the hazards are running. The only issue/strange thing going on is the trailer indicator flashes as well.
Old January 18th, 2015, 12:04 PM
BlackField's Avatar
BlackField
Oscar
D110
Thanks guys all helpful information. I sounds like since I don't see a hazard triangle lamp anywhere that 8 is not required. It looks like the left right indicators should do the hazard flashing... maybe.
Old June 16th, 2016, 10:34 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just found this thread. its good reference. I need to do this asap.
Legend in My Own Mind.
Old August 8th, 2016, 12:59 PM
BlackField's Avatar
BlackField
Oscar
D110
It's installed and works as advertised let me know if you need any more info. 1 and 2 did end up being 12v IGN + and live + on my switch.
Old September 28th, 2016, 04:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I guess you don't have a pic of the plug after you completed it. I need to do this tomorrow so I can wrap up a dashboard.
Old September 28th, 2016, 05:26 PM
lordhelemt's Avatar
lordhelemt
Paul
Here's a pic of the plug wired as indicated earlier on this thread. The only thing I haven't figured out is when the hazards are on both the left and right indicators and the hazard triangle flash on the binnical.
ID:	158602   Click image for larger version
Old September 29th, 2016, 09:01 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Great. Thanks for the pic...
Old October 11th, 2016, 12:22 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Finally got around to this. Was simple as pie
td5, wiring
Hazard switch wiring jjstahl3 Defender Technical Discussions 1 August 27th, 2012 08:40 PM
MUD UK Hazard Switch Wiring sonoronos Defender Technical Discussions 6 December 19th, 2011 02:49 AM
Hazard Switch Wiring CDeWan Defender Technical Discussions 0 February 18th, 2009 12:53 AM
hazard switch wiring Overlander Defender Technical Discussions 18 January 12th, 2007 08:09 AM
The Brits of Hazard Eric Siepmann Misc. Chit-Chat 14 December 15th, 2003 02:15 PM
