TD5 Fuel Tank Sending Unit - Defender Source
Old July 21st, 2016, 12:45 PM
Does anybody know if a TD5 fuel quantity sender uses different resistance than the standard sender? My gauge shows full when full but never goes down below 3/4ish with the tank near depletion. I'm hoping to not have to drop the tanks to change out the sender.
Old July 21st, 2016, 12:49 PM
They should be the same. Lots of people use a TD5 gauge cluster in older vehicles.
Old July 21st, 2016, 12:59 PM
Great, guess I'll be dropping the tanks. Any idea if the hole for the sender is different than an older tank?
Old July 21st, 2016, 01:03 PM
Older tanks had the sender in the side of the tank (no need to drop). AFAIK, TD5 uses the top port for a combined fuel pump and sender. I'm not exactly clear what you have in your truck.
Old July 21st, 2016, 01:09 PM
It's mounted on the top. The tank is a WHK100050
fuel, fuel tank, td5
Leak at Fuel Level Sending Unit?? Lesandjes Defender Technical Discussions 2 December 7th, 2015 07:40 AM
STC1139 Fuel Tank Unit 90 w/ In Tank Pump 89Defender90 For Sale - Parts 0 March 28th, 2015 01:13 PM
Need a 110 Fuel sending unit for early truck Uncle Douglas Wanted 19 September 18th, 2012 11:40 AM
WTS: 110 fuel sending unit, Terrafirma spring retainers, Land Rover Gear Sandals mcoleman762 For Sale - Parts 4 October 6th, 2011 08:13 PM
Need Oil light sending unit, 97 90 or Disco Tom Fitzgerald Wanted 2 April 14th, 2007 09:57 AM
