Td5 fuel Pump with a 200tdi - Defender Source
Old March 6th, 2011, 08:59 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
My plan is to use the fuel system from the td5 frame with my 200tdi engine, my question is whether I should use the fuel pump that that the TD5 has in the tank along with the 200 lift pump or disable the intank pump somehow.
Also some thoughts on leaving the filter by the rear wheel as opposed to on the bulkhead where the 200 normally is.
Many Thanks
Old March 6th, 2011, 09:18 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I wouldn't use the in tank pump. Use the 200 mechanical.....keep it simple. The "filter" at the back wheelwell is a separator (cylonic) which you can leave AND use the filter underhood.
Matt Browne
Old March 6th, 2011, 11:01 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Td5 pump is also very high pressure.
I've got a number (somehwere...) for the RoW plastic tank pickup "pipe" for non Td5 engines, eventhough on microcat it's still called "pump" it isn't a pump
Old March 6th, 2011, 12:28 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
that number would be really helpful.
thanks
Thanks Matt, Simple is what I'm looking for
Old March 6th, 2011, 03:02 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
For the 90, it's WQB100430 (see a picture here)
110, is WQB100440 (picture)
Old March 6th, 2011, 03:45 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks.
I wonder if you could run the existing setup and just disable the pump part?
Old March 6th, 2011, 08:39 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you decide to do away with the Sediment separator on the rear frame let me know I would be interested in getting it from you, that is if you do not want it.
I have heard people in the UK using a electric fuel pump instead of the manual pump on a 300 Tdi? Couldn't find the blog. So..sounds like it could be done?
Land Rover 110
Old March 7th, 2011, 05:09 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
You need a ROW, rest of world, tank top piece that replaces the td5 pump etc with a simple set of tubes and use the lift pump on the engine.
Old March 8th, 2011, 07:01 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
HI Marcus
That's the numbers i posted above...
Old March 8th, 2011, 02:14 PM
T1G UP's Avatar
T1G UP
marcus
Originally Posted by diesel_jim View Post
HI Marcus
Hi Jamie! seen that.
Old March 9th, 2011, 09:39 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mine has 4 hoses off the sender, these only have 2? What would you do with the extra 2 hoses?
Old March 9th, 2011, 10:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
On the Td5, two of the pipes circulate through that under wheelarch filter, then back into the tank again. only 2 pipes go up to the engine (flow & return)
200tdi, fuel, td5, tdi
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
