TD5 fuel pump - Defender Source
Old August 21st, 2014, 06:46 PM
Ttuck3r's Avatar
Ttuck3r
Tommy
1999 Defender TD5
Im completely lost, a week ago my 90 didn't start I noticed my lift pump not working took the key out the ignition, back in and it started up, on fri it did the same and this time it's not recovered. 1) All wiring front to back is good for continuity 2) Fuel pump is good, tested from green relay by gear shifter. 3) Checked relays with 12v supply and multimeter and they are all good 4) all fuses are good And yet i still have no fuel pump when i turn the ignition on....could it be my ECU or even the crank position sensor? Tommy
TD5 -tdci Defender FUEL PUMP SEAL WGQ500020 Ben01 For Sale - Parts 0 July 4th, 2013 11:31 PM
TD5 fuel pump Shawn Wanted 4 May 19th, 2012 07:42 PM
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
Td5 fuel Pump with a 200tdi tomaco1 Defender Technical Discussions 11 March 9th, 2011 10:54 AM
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
