Td5 110 opinion - Defender Source
Old November 16th, 2012, 11:41 AM
rcfarris's Avatar
rcfarris
Rory Farris
multiple
Td5 110 opinion
Thinking about rhino lining my td5 110. Truck had carpet which has been removed revealing some surface rust. Want to prevent this from recurring. Also considering ex moor matting kit. Thoughts??
Old November 16th, 2012, 11:50 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I wouldnt do it. Its really hard to undo. If you are not going to dynamat and carpet, with the paint code you can always get a paint supply shop make up some paint in a spray can for touch ups. I have had the Beluga Black and Alpine White made up for this same issue. In the SW, I ended up going back with carpet and mat.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old November 16th, 2012, 12:07 PM
NOOOOOO!
Get a NAS D90 ST rear rubber mat for the back (trim to fit) and get mats for the front and seat box.
Old November 16th, 2012, 12:18 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Much of my 110 rebuild has centered around mechanical issues, followed by rust mitigation and acoustics. While the body was completely apart, post-paint, I sprayed the rear tub, seat box and inside of the aluminum door skins. I used Line-x. I have mixed feelings about it. The body structure is rather porous and the lining can help to seal many of the tub seams. It will also change the frequency at which the tub resonates ala VDM like Dynamat, Fat Mat etc. On my tub, the guy laid down ~.125" on the sides and ~.25" on the floor. The unanticipated floor thickness messed with some of the tolerances for my roll cage install. Not terrible, but an unanticipated PITA.
IMO, fix your rust issues and yank the carpet. Get the 3 piece Exmoor Trim seat box and tunnel mat set and a heavy rear bed mat..
1970 SIIA 88, Sold
Old November 16th, 2012, 12:50 PM
tommyd's Avatar
tommyd
Tom
LR3
I don't get why some people hate spray-on liners so much. I have it in my truck and love it. If you have rubber mats on bare floor, water can get trapped just like with the carpet and lead to rust, right?
I have the Exmoor molded mat on top of the liner and don't worry when water gets underneath.
Old November 16th, 2012, 01:07 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Worst thing the previous owner did to my truck. Don't so it. Fix the rust, good paint and your set. It's rough and annoying every time you touch it, it doesn't stop stuff from sliding around anyways
Don't do it!
Old November 17th, 2012, 08:13 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Once bed lined the modular design is taken away. If you ever want to pull the floor boards you will have a hard time doing it unless you pull everything and have it lined separately. Of course if you never plan on taking things apart then it is a non-issue.
Land Rover 110
110, td5
Land Rover Defender 110 Galvanized Chassis TD5 draaronr For Sale - Vehicles 8 June 9th, 2015 04:27 PM
WTS: TD5 Boost Box and 110 Springs Oxcart13 For Sale - Parts 4 October 4th, 2011 06:57 AM
Overland Ready Defender 110 TD5 draaronr For Sale - Vehicles 0 June 2nd, 2011 09:58 AM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
