TCase Removal, WTF? - Defender Source
Old August 26th, 2010, 03:38 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
TCase Removal, WTF?
Attempting to remove my TCase and I am stuck. I removed the 4 bolts and nut per the manual, along with the bolt next to the hi/lo shifter. All linkages, wires, vents etc are disconnected. The problem is that the tcase won't budge, any ideas?
Semper Fi!
Old August 26th, 2010, 03:58 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Off the top of my head, I think there are 6 all together... 2 from the front and 4 from the back..
Legend in My Own Mind.
Old August 26th, 2010, 04:00 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yep, per the manual, 6 bolts/nuts. This friggen thing isn't moving.
Semper Fi!
Old August 26th, 2010, 04:01 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Might be stuck on the input shaft that comes from the transmission? you give it a nice hit with a rubber mallet yet? I can't think off the top of my head but last time I did one I thought there was 2 nuts that faced the other way along with the 4 or so bolts that hold it to the tranny.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 26th, 2010, 04:11 PM
WLDKGDM's Avatar
WLDKGDM
Dan Cronin
1997 D90 SW
Transfer case mounts disconnected?
Cross Member removed?
Have it lowered so the shift lever is clear of the tunnel window?
More than likely, the mating surface is just holding fast.
It does take a bit of prying to get it to break free.
Wear The Fox Hat.
Old August 26th, 2010, 04:18 PM
I remove the cover plate and pull the input shaft and gear-makes for a hell of a lot easier install as well. I've seen them where the Brits have used silicone between the tcase and transmission face. I guess they do this incase they ruin the input shaft seal which is easy to do but make removal a bitch. There is a stud on most on the left side that the ground cable bolts to-that stud usually has a second nut underneath the cable that may be holding you up.
Old August 26th, 2010, 04:42 PM
Wolf Fabrication
Sterling Archer
'08 D3
Finally got it out. Took a lot of coaxing with the improper tools.
Time to re-gear to 1.4 gears!
Semper Fi!
Old August 26th, 2010, 05:45 PM
dchapman
Daniel Chapman
1999 D1
I guess all it took was a little common sense.
Old August 26th, 2010, 06:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yes, thanks for the kernel of wisdom.
Semper Fi!
Old August 26th, 2010, 07:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
He never would have got it out if that were the case.
Old August 26th, 2010, 09:41 PM
dchapman
Daniel Chapman
1999 D1
lol.
Old August 27th, 2010, 08:41 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
regearing the T-case? Just the low side or installing a disco/higher high gear ratio T-case?
I have a dead Disco T-case in my basement that I'd like to fix and get a lower low gear ratio, but so far I did not find source any part at a price that fit my wallet. (that's not even considering the time it'll take of course! ). Seems like the cheaper approach will do lower diff gears and higher high gear ratio.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 27th, 2010, 09:40 AM
Focus Loic, focus! Must.....get.....truck.....running. Then worry about other crap.
Old August 27th, 2010, 11:17 AM
The Dro
Dro
1988 Ninety
hey... hey... He has LRD... Land Rover Disorder... like the rest of us.
We need a focus group...
Old August 27th, 2010, 05:00 PM
Wolf Fabrication
Sterling Archer
'08 D3
I have a Disco 1.2 case and am swapping in Defender 1.4 gears. My truck was too sluggish rolling on 35"s.
Semper Fi!
Old August 27th, 2010, 11:07 PM
not done yet ?
Old August 28th, 2010, 05:55 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by 130Tdi View Post
not done yet ?
Today, wife and kids willing. I got sidetracked by the Willys that needed some love.
Semper Fi!
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
tcase for sale vlocci For Sale - Parts 5 May 25th, 2004 07:14 AM
