Tapping sound from brakes? - Defender Source
Old July 19th, 2004, 08:27 AM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
Guys, I am no professional mechanic but I am no slouch either. I have noticed that my '97 has a tapping sound coming from the front end. It increases speed with increased road speed. The noise instantly goes away when I touch the brakes.
My question is what the heck in the brakes or that general area could be responsible for a tapping sound? This is not what I would expect from worn brakes which might squeal or have a rattle sound but this is a very precisely rythmic tapping sound.
Any ideas??
Larry
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
Old July 19th, 2004, 09:40 AM
I would pull the front wheels off and have a look, see if anything is caught in the breaks. Possibly the rotor is warped.
Old July 19th, 2004, 01:23 PM
MDNIBTY
Wally Dalton
95 d-90
Thumbs up
Larry
You may want to check out the gas tank. Sometimes I once had a clicking sound and turns out there was a rock in my tire treads, and a zip tie was hitting the tank. You may even wants to check the wheel weights are not should be hitting the brake shields or tie rod endses.
Old July 20th, 2004, 03:05 AM
Cyborg
Larry Walton
Wheel weights could be the case....good idea!! I do not think it is likely to be warped rotor though because I would think I would feel a pulsating in the pedal right?? Brakes feel and work fine. I will check this out when I get a day off this coming Wed.
THX Larry
Old July 30th, 2004, 03:08 AM
MDNIBTY
Wally Dalton
95 d-90
Sosa Didja fand anything? Im kurius what was makin that klickin.
Old July 30th, 2004, 03:47 AM
Cyborg
Larry Walton
No I have not...I have been too busy to actually look yet. I am not certain it is coming from the brakes themselves or not but hiitting the brakes makes the tapping go away somehow.
Larry
Old July 30th, 2004, 05:31 PM
Wheel bearings loose. Could be cv but probably wheel bearings. Jack up vehicle, shake wheel by holding at 6 and 12 and if you can wiggle it then you know what it is.
Ron
Old August 1st, 2004, 08:57 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Check the brake pad return springs. On my '95 Defender they are coil type springs.
I had the same problem with mine and all I had to do was stretch the springs out a little to stop the noise.
brake
Help...When I press on the brakes, I hear a knocking sound WEMICHENER Defender Technical Discussions 4 February 17th, 2007 04:24 PM
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
