Tapping Sound after replacing headgasket - Defender Source
Old April 4th, 2010, 10:38 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I just got the headgasket replaced about a week ago and since having it done i am hearing a whole new tapping from the the motor. It does it after warming up and is subtle enough that you would let it pass. I hear it the most when downshifting. Since the heads were shaved at a machine shop, you think the sound would be a tappet? i know it isnt a lifter. It sounds isolated and follows the revs of the engine. Other than that the truck runs perfectly fine.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old April 4th, 2010, 12:46 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Could be a valve also, or a rocker arm, or a valvespring. Also possible that it's an exhaust leak somewhere. Lots of little possibilities to track down unfortunately.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 4th, 2010, 02:50 PM
9/10 it is a rocker arm. When people do heads they clean the gunk off them and then they tap.
Take it back and complain.
Old April 5th, 2010, 08:12 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Brian, if the heads were stripped and cleaned Ron is spot on, also the rockers and pushrods would have worn in together it may be it was reassembled with the push rods and rockers mixed up in this case it causes rattles as the wear spots don't match, the same thing is caused by mixing new and old parts.
you may find it clears up as the wear will rapidly even out, keep a close check on oil and filter changes as disturbed crud will be floating about
I have also seen the hard steel wear pad on the rocker arm come loose and cause a sound like a double tap, similar to a train running over a rail joint... cue boxcar willie train whistle.
regards
Gren
Old April 5th, 2010, 08:15 AM
I had the same thing happen on my Range Rover, my new cleaned rocker assemblies with old non mated push rods and its making a ticking noise. It would also have to be the rocker on the DS thats a bitch to get too.
Old April 5th, 2010, 08:28 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I have the same thing with mine after I put in new heads. Is this something to be concerned about? or will it clear up after a bunch of miles?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 5th, 2010, 06:23 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
If the sound sticking around by the weekend, I am going to run it back up to the shop. It is hard for me to figure out exactly where it is coming from. It doesnt sound like its in the top end. I hear it best under the truck, which I thought was a little strange.
1995 Defender ST
1996 Discovery SE7
ac, gas
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
