Tappet/lifter tolerances after rebiulding heads - Defender Source
Old January 17th, 2007, 02:55 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I'm surprised nobody has really discussed this issue on this forum besides being detailed on the RPI site. I've searched but to no avail. Do any of you guys actually do this step and then appropriately shim afterward? Is this procedure done due to the head being decked out too much or is it due to varying valve seating height? Any help is appreciated thanks.
Neil
Old January 17th, 2007, 04:48 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yes, we check all the 4.6s after head work and shim as needed.
Email:
Old January 17th, 2007, 05:25 PM
Neil McCauley
Neil McCauley
Hi Mike, I feel like I'm talking to a celebrity. hehe Anyway I just have a few questions if its alright. 1. Is it true that brand new heads that come mounted on new long blocks do not need to have its tappet clearance checked? 2. Is it the decking of the heads to make them flat the culprit for changing the tolerances or is it differen't valve seating measurements or mabye both? Thanks.
Neil
Old January 18th, 2007, 08:28 AM
ECR's Avatar
ECR
In most engines, like GMs and others you can buy various length push rods depending on what you ahve doen to the heads. Sadly the Rover v8/Buick 215 is not a very popular engine so no one makes custom length push rods for the masses. The cure is to use shims under the valve bases to again achieve the correct length for the push rod. If you shave the heads and don't make up that distance in the head gasket then you have to somehow correct for the now shortened distance from point A to point B (push rod length). The shims allow you to do this without the need to get costly custom push rods made. The need for it depends on what was done to the heads. If everything is factory fresh and not rebuilt then you should not need them, but if the heads are rebuilt, or the block deck is shaved, it is worth checking as incorrect push rod length means valves not working the way they were designed to. Its a picky thing to check and most don't do it. It really depends on how correct you want everything set up, and what was done to your block and heads.
Have fun
Email:
3.9l Heads For Sale DesertRat For Sale - Parts 0 October 13th, 2006 08:56 PM
Wolf XD mirror heads - anyone using these? solihul Defender Technical Discussions 8 May 18th, 2005 01:03 AM
Redo heads or not? mlw911 Defender Technical Discussions 14 October 21st, 2004 02:42 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
superficial rust on bolt heads 97 SW kevincdoyle Defender Technical Discussions 3 January 3rd, 2004 09:55 AM
