Tam tam ... Tam tam. Pitman arm puller near beacon NY needed. - Defender Source
Old August 11th, 2012, 06:05 PM
Tying to remove drop arm Autozone pitman arm puller is just crap. Anyone nearby with a decent one? Will pay in cash and beer!!
Old August 11th, 2012, 06:45 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Come to my house
Old August 11th, 2012, 08:00 PM
Originally Posted by tjfslaughter
Come to my house
Are you back?
Old August 11th, 2012, 09:43 PM
after trying heat ... have left it with someone who is going to use a hydraulic puller on monday ... need a seal for the bottom as the current one failed to heat exhaustion from the blow torch ...
Old August 11th, 2012, 09:57 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Did mine a few months ago. It was an absolute bitch. Heat it, beat it, put a puller on it, then do it again.
Old August 12th, 2012, 08:52 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I posted this on another forum last year:
I recently replaced the steering box on my wife's '97 and while I've used various methods for removing the drop arm, mainly heat and hammering, this time I decided to do it "right", especially since I may rebuild the old box myself and didn't want to risk any damage.
After some research I found that the OTC6497 Ford Super-Duty Pitman Arm Puller fits & works perfectly.
A call to OTC tech support connected me with someone very helpful who got one of the pullers while I was on the phone and took measurements.
Others I looked at were too small and/or cheap).
This is the cheapest place I could find it.
OTC 6497 Front End - Puller
Very good customer service, with only minutes to spare before UPS came, they rushed my order to make the pickup that day.
Even with the puller, I had to place a 4ft pipe on the drop arm and stand on it and use my high-lift handle on my breaker bar to pull the arm.
This will work on 89-99 D1's
87-on Defender
92-94 RRC
Maybe others, I'm not sure
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
ac
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Pitman Arm 97 D-90 97Ariesblu Wanted 12 May 20th, 2007 09:35 AM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
