taking oil level after oil change - Defender Source
Old May 8th, 2013, 06:58 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Thanks to all who contributed to the numerous threads about oil change procedures. really helpful.
I followed what seemed to be the most used process and oil light never stayed on.
Curious though about engine oil levels. When do you get the most accurate reading of the oil level? seemed like I was getting a higher reading (about halfway between the "N" and the top "High" mark after I let the truck run for a few min.
After it sat for 10 or so, the reading was just at the middle notch "N".
Just curious what best practice is here. I dont have an owners manual but recall reading I want the level at the middle notch, right?
Oh, and did the diffs today too! quite a successful night I must say! I know its simple stuff but who know where this Ex MOD has been and its service history. Happy to start a clean slate.
Old May 8th, 2013, 07:31 PM
Fill a **** hair over full it will leak out
Old May 8th, 2013, 08:31 PM
josh-man's Avatar
josh-man
joshua
Uhhhh, what? is full at the middle notch? best to check when hot, cold?
Old May 8th, 2013, 10:28 PM
Or 2 knats cocka?
Old May 8th, 2013, 10:42 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Cold. Any equipment operator or truck driver (people who make a living with diesel motors) will tell you to check the oil and water BEFORE you turn the machine on and do any damage should somthing be amiss.
Old May 8th, 2013, 11:44 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
1. What does the book say your total engine oil capacity is ? Pour it in.
2. Are you using the correct volume oil filter ? ( bigger or smaller will change vol. in pan )
3. Start 'er up, let the oil light go off, shut it down, let sit for a good long time.
4. What shows on the stick ? This is the full level based on the book fill capacity.
Oil Change gtg067i Defender Technical Discussions 31 July 13th, 2005 10:24 AM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
