Taking Glass out of Windshield - Defender Source
Old November 10th, 2012, 07:53 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hi everyone. I have a new take off windshield for my restoration but it is not the right color. I need to take the glass out so I can paint the frame. I have researched and found a whole lot of topics on how to refit the glass with the string method. Anyone know how to properly TAKE OUT the glass without breaking it? I have read that we can cut the seal to remove it but I would like to try and save the seal since it is new. Thanks in advance.
MUDSUX
Old November 10th, 2012, 08:02 PM
If you tape it up real good, it's paintable. Much easier off the vehicle!
Old November 11th, 2012, 12:48 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Call up a local glass repair place and ask them how much to remove the window for you without cutting/damaging the seal.
Old November 11th, 2012, 08:17 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Most windshield shops will want to cut the seal and still will not guarantee that the glass will not beak. If you are careful and take your time in taping the rubber you can paint with the windshield in. Most body shops would just tape and paint.
Land Rover 110
Old November 11th, 2012, 08:37 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks for all the obvious suggestions I have already considered those options. I would rather not tape if I can avoid it and since I have done everything on this truck myself for the last 3 years, I would like to do this myself too.
MUDSUX
Old November 11th, 2012, 08:55 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
It can be done but chances are you will break it and the seal is cheap compared to the glass
Just cut the seal
Old November 11th, 2012, 08:58 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Just cut the seal
I am leaning this way Dave. Just thought maybe someone knew a trick to do it.
MUDSUX
Old November 11th, 2012, 09:42 AM
Ok then use tape between the frame and glass carefully cut the seal and allow the glass to drop out enough to separate the two
Old November 11th, 2012, 11:29 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Your preference for genuine v. pattern parts may sway your decision. The old seal on mine was perished. Pattern seals (e.g. Britpart, all makes...) were ~$15-20 while genuine ~$100. Stephen had a NTO windshield, glass, seal and frame for just a bit more. I ended up masking around the seal and painting the frame. Due to reports of poorly fitting pattern windshield seals I wanted a genuine seal.
Edit: a genuine seal on a LR, ha!
1970 SIIA 88, Sold
Old November 11th, 2012, 11:47 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks Paul. Thoughtful insight as always. I bought the windshield from Stephen. It didn't make any sense to spend $150 to replace the cracked glass on my old windshield when I can get a new complete windshield for not much more. This is why I want to save the seal, because it is genuine.
MUDSUX
Old November 11th, 2012, 12:12 PM
i would have thought a new pattern seal would be better than a genuine seal refitted ... you are likely to cause some damage taking it out no matter how careful you are.
Old November 11th, 2012, 12:29 PM
grnrvrs's Avatar
grnrvrs
Paul
88
If the pattern seal is crap, then it is crap regardless of what might happen with refitting a genuine seal. Hence my decision to mask.
1970 SIIA 88, Sold
Old November 11th, 2012, 12:56 PM
I have a pattern seal and it's perfectly fine.
Old November 11th, 2012, 01:21 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Ok, so who made it? A good alternative to genuine would be welcomed.
1970 SIIA 88, Sold
Old November 12th, 2012, 08:09 AM
winn442's Avatar
winn442
Winn Bearden
Do what the body shops do....push string under the seal, that will raise the lip of the seal off the frame....mask off the seal and paint. The paint will go under the seal, and you won't be able to tell that it wasn't removed.
Winn Bearden
Old November 12th, 2012, 08:54 AM
Proline from RN
Old November 12th, 2012, 09:53 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks!
MUDSUX
Old November 13th, 2012, 12:05 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Update here
MUDSUX
glass
Defender glass choices-lessons learned Overlander Defender Technical Discussions 1 May 14th, 2010 10:51 PM
POE Lift Gate and Glass TDI Guy For Sale - Parts 11 May 25th, 2006 05:02 PM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
