Tailight issues - Defender Source
Old August 1st, 2005, 10:05 AM
rustydefender
Russell Newton
97 D-90 sw
Tailight issues
I had my left tailight burned out a few days ago so i cleaned the connections and replaced the bulb and cleaned it up. It comes on but only when my lights are on. It wont come on when I brake and it won't get brighter when i break at night. I don't think it is a faulty bulb because I tried a few bulbs and both filaments look fine. None of the connections seem to be loose or broken. Has Anybody had this problem? How do I fix it?
Old August 1st, 2005, 03:30 PM
Sure the bulb is in right, sometimes they can screw in the wrong way. I would use a chunk of 2x4 or something to hold the break peddle down and then screw around with the bulb and wires until the light came on or sparks fly out, if sparks fly continue until your satisfied
Old August 1st, 2005, 04:05 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I had the oposite problem, brake light worked and the tail light didn't, a Cop was nice enough to let me know of the issue. It wasn't the bulb, it ended up being a bad connection with the wiring. I cut and respliced the wires, seems fine now.
Old August 2nd, 2005, 10:14 AM
rustydefender
Russell Newton
97 D-90 sw
where did you re-splice your wires?
Old August 2nd, 2005, 01:45 PM
m.michaels
Matthew Michaels
1997 D90 SW
Ditto - I had a similar problem on my '97, and found that cutting and resplicing the wires was the best bet. Also one of my bulb holders was a bit suspect (lots of corrosion), a new one solved that problem as well. Smearing a bunch of dielectric grease inside the connector has kept the corrosion down in there as well - no problems.
In fact I ended up cutting and re-splicing the wires for all of the rear lights, wrapping the splices with that heat shrink, and then wrapping enough tape around the whole affair. I also drilled holes in the bottom of all my lenses to let the water drain out and have not had any problems since then.
Have fun . . .
Old August 2nd, 2005, 02:44 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check the disconnect from the wiring harness to the light socket. You will probably find that it is corroded and one of the pins is broken. That is very common.
Old August 2nd, 2005, 05:37 PM
sheki's Avatar
sheki
David Shechter
I spliced it where there was a split in the line, where power was being jumped to another light. You should also check the harness and connection at the bub. They do corrode, and the pins do break off, just had to buy a new harness and connector from Rover's North.
Old August 4th, 2005, 01:03 PM
rustydefender
Russell Newton
97 D-90 sw
already checked harbesses cleaned them out and they look fine
ht
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Server issues chrisvonc Support & Suggestions 4 June 16th, 2005 01:17 PM
'94 Tailight Sockets! scot Defender Technical Discussions 10 January 24th, 2005 10:36 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
Getting Help, Outstanding, & Known Issues chrisvonc Support & Suggestions 0 May 23rd, 2004 06:00 PM
