Tailight failure - Defender Source
Old August 13th, 2005, 03:27 PM
rustydefender
Russell Newton
97 D-90 sw
Tailight failure
My right tailight does not work when the brakes are applied. I replace the bulb cleaned the connections etc. Now it works but only when the lights are on and it does not brighten when I apply the breaks. Is my problem a worn out wiring harness? If so can I get a replacement at a local autoparts store or do I have to order them?
Old August 13th, 2005, 03:55 PM
scoloco's Avatar
scoloco
'94 D90 ST
Fuses?
Old August 13th, 2005, 04:27 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
check your wiring harness to see the condition of it, try cleaning it out if you can. It may be very corroded and needing to be replaced. I just had to do one, I got the parts from rovers north ($18). It could also be a loose connection, you may want to take a look at the splices in the wiring to see if one is loose.
Old August 14th, 2005, 01:05 AM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
Check your grounds. It seems like a lot of 97's have that problem.
'97 D90 - 4.6
'00 D2
Old August 14th, 2005, 01:16 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The tail light assemby plugs into the wiring harness (the bulb holder unplugs). If you unplug this connection, you will see that one of the three pins is broken due to corrosion. You will need to replace this connector/bulb holder. When you replace this connection, fill the female end with silicone to prevent this again.
Old August 14th, 2005, 10:09 PM
rustydefender
Russell Newton
97 D-90 sw
I already checked the connections all three prongs are intact and the connections look pretty clean.
Old August 14th, 2005, 10:31 PM
loved90's Avatar
loved90
Jay Love
I have exact same problem, tail light works and blinker works, but brake light does not work on right side.
Old August 14th, 2005, 11:20 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Is it only the right side or all the brake lights?
Old August 15th, 2005, 12:50 PM
Set something on the break peddle and play with the bulb to see if you can get it to come one, I have to do this sometimes when replacing bulbs to get everything lined up just right.
Old August 15th, 2005, 01:23 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I had a similar problem & it turned out to be a bad ground wire. The ground was enough to light the bulbs while running only, but braking pulled too much current and they wouldn't come on.
ht
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Tailight issues rustydefender Defender Technical Discussions 7 August 4th, 2005 01:03 PM
'94 Tailight Sockets! scot Defender Technical Discussions 10 January 24th, 2005 10:36 PM
