Tail Light out - Defender Source
Old May 1st, 2011, 08:50 PM
61rover's Avatar
61rover
John Crouse
Tail Light out
Checked many threads, but can't find what I'm looking for. '93 NAS D110. Left tail/brake light is out (both parts). Bulb is good. Right side is fine. What fuse is this on? Couldn't tell from cover diagram or manual.
Old May 2nd, 2011, 06:34 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Tail lights should be on the same fuse. Did you check the contacts to make sure that they are not corroded? Get a tester to make sure that you have power to the fixture. Your wiring harness is on the right side, ROW trucks are, then you have a group of wires going to the left behind the gas tank. I would check them for a break in the wires.
Land Rover 110
Old May 2nd, 2011, 12:38 PM
exmod110's Avatar
exmod110
Don Lang
Check the ground for that.
85 exmod 110 rhd 300tdi
Old May 2nd, 2011, 12:49 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
In a NAS 110 the parking lights are fused for LH side and RH side independently. The brake light is on another circuit, so if you have the rear parking light out, the brake light on that side out but the side marker lights are working on that side it points to, as others said, to a bad ground or a fixture that just isn't making the correction correctly. It can also be some of the Lucar connectors behind the rear speaker on that side. They corrode over time as a lot of NAS 110s leak water in that area and it messes with the ground and the connectors.
Email:
Old May 2nd, 2011, 09:13 PM
61rover's Avatar
61rover
John Crouse
Thanks Mike. I was afraid of that. I hate that rats nest behind the speaker.
Old May 10th, 2011, 03:15 PM
61rover's Avatar
61rover
John Crouse
Ok, now all left side out except turn signal. Running lights, tail light, and brake light out. Fuses and bulbs are all good. Where should I look next? Where (specifically) is this cricuit grounded?
Old May 10th, 2011, 03:44 PM
Behind the speaker.
ht
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Need tail light lenses and Jerry can holders Cyborg Wanted 2 January 13th, 2006 12:20 PM
Tail light lamp guard sheki For Sale - Parts 4 January 12th, 2006 08:50 AM
Rear lamp guards (tail light) mod4b Wanted 1 August 2nd, 2005 05:06 PM
Tail light in the dark... OCD90 Defender Technical Discussions 16 June 1st, 2004 12:31 PM
» Defender Registry
D90
NPT90
Osiris
WD90
Add your Defender
