tachometer bouncing all over low range - Defender Source
Old May 31st, 2015, 05:29 PM
ymc226
Lawrence
1995 D90 SW NAS
Took my Defender to have an engine noise looked at which my mechanic couldn't locate the problem but removed valve covers and intake plenum and put it back together. The tapping still occurs but drives normally.
I get it back but the tachometer stopped working correctly. It is now very bouncy and indicates almost always in the very low range (0-1 K) irrespective of how hard I am pushing the gas. The only time it is somewhat accurate is when it is out of gear in idle but the needle still bounces more than right before I had work done on it.
I'm getting a little frustrated. Is there anything I should look at inside the engine compartment myself that would be a simple adjustment as I'd rather not have him work on it again.
Old May 31st, 2015, 05:39 PM
Check to see that it's fully plugged into the back of the alternator.
Old May 31st, 2015, 05:46 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Yup- or maybe your alternator is on its way out... More likely the connection since you just had work done.
Old May 31st, 2015, 05:58 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks guys. I usually don't work on cars; just started oil and filter changes with the acquisition of the Defender. I fix hearts (put stents in arteries) not cars.
Can anyone take a cell phone pic of the alternator and where the plug for the tach should be so I can check it.
Old May 31st, 2015, 06:02 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
From my '94...
Best of luck,
Jay
Old May 31st, 2015, 06:21 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Jay and all. I just pushed it in and all is well.
I looked on the RN site and an OEM LR alternator is close to $800 while a Proline is about $300.
Now, I just need to find a local mechanic who is more detail oriented and who knows older LR well.
ac
gas guage bouncing around CDeWan Defender Technical Discussions 8 April 18th, 2012 12:21 PM
Bouncing Odometer - Finally Died wicks Defender Technical Discussions 22 November 7th, 2006 07:13 PM
bouncing fuel gauge mattdh Defender Technical Discussions 18 June 13th, 2006 02:17 AM
Rubicon rentals all over Maui..... mauid90 Misc. Chit-Chat 2 January 7th, 2006 01:32 PM
bouncing d-90 Rick Carlisle Defender Technical Discussions 17 May 11th, 2004 10:20 PM
