Tach to Alt connection? - Defender Source
Old July 9th, 2009, 10:23 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does this alternator have a place to connect a tach to it? I'm wondering if I can connect to the extra spot where the warning light attaches(yellow), or where the cable to the battery attaches (red)
Old July 10th, 2009, 11:22 AM
No, none of those spots. If it has one, it will be labeled "W".
If you do not have one, you need to tap into the raw AC feed before the rectifier. Hard to see if something is accessible in your picture. Take some better pictures and I can let you know where to connect.
Old July 10th, 2009, 12:15 PM
Tom,
The back of that looks nothing like mine. Where did you get that alternator ?
Old July 10th, 2009, 12:19 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
thanks, john.
The rectifier is the Brass square looking thing right?
its out of the old engine, the 2.5 gas. the one I got with the 200 was a bit beatup looking and this was brand new and it fit.
Old July 10th, 2009, 12:22 PM
I have been looking for something else that will fit. The stock alt is only 45 amps
Old July 10th, 2009, 08:38 PM
No, AFAIK the brass thing is the noise suppressor.
The rectifier is built into the three plates below the red arrows.
Old July 10th, 2009, 09:32 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mo pics
I hope these are clear enough
ID:	20488   Click image for larger version
Old July 11th, 2009, 09:25 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Try Iskra.
- Charles Eames
Old July 11th, 2009, 11:47 AM
From what I can see the heavy wires coming from below with the white fabric insulation should be the raw feed from the alternator. Any of those should supply a tach signal.
The Defenfer 200TDI alternators come in 45 and 65 amp versions.
Old July 11th, 2009, 12:04 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
ac
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
tach question, sorry if redundant (warning) Neo Defender Technical Discussions 5 October 7th, 2005 04:24 PM
Think there is a connection? JohnK Misc. Chit-Chat 2 April 6th, 2005 01:16 AM
140amp alterantor from rover connection - ROCKS! solihul Defender Technical Discussions 5 March 19th, 2005 02:42 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
