tach question, sorry if redundant (warning) - Defender Source
Old October 4th, 2005, 10:28 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Hey all, I have tried searching for about 15 mnutes and get the hated "page not found" error and am at the end of my line, so in advance, I sincerely appologize for this redundant thread cause I KNOW I have seen this info posted before. So , here goes....
Recently my 95 D-90 tach started bouncing down to 0 and then back up to indicate an accurate (as far as I know anyway) reading of engine RPM. It is intermittent and will flutter up and down as I drive. There is no other indication. I thought I had read it had to do with an alternator connection, and did check those and the connection on the back of the tach. Any enlightenment is greatly apprecaited. Thank you all in advance.
JBR
Pain is weakness leaving the body
Old October 4th, 2005, 10:34 PM
Kneel
Neil Flanagan
94 D90 ST #1092
Alternator time.
Old October 5th, 2005, 08:41 AM
Yep there is a small wire on the back of the alt, make sure it is on their good and tight. Maybe run down to autozone and have them test the alt for you to make sure it is good.
Old October 7th, 2005, 10:24 AM
Tom Rose
Tom Rose
tach
sometimes brushes will do it. they are cheaper than a new alt.
Old October 7th, 2005, 12:42 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Thanks guys. If it the alternator, is there a considerably better option to the stock LR one? Thanks again!
JBR
Old October 7th, 2005, 04:24 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
In my RRC i used a British Rotating Electronics one that I purchased from DAP, and didn't have problems with it for the rest of the trucks life. You could also look into having a local alt. and starter shop re-build it. I have had a local shop re-build one of my alt.s and the hot-rodded it for a bit more power.
I got your JEEP thing, now it hurts when I pee!!
ac
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
