tach light - Defender Source
Old August 24th, 2011, 01:07 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
tach light
My illumination light on my tachometer works only intermittently, it will usually just stay off unless I hit it or tap it a few times, lately that method has stopped working as well. I recently replaced all the dashboard lightbulbs so I'm sure it is not the bulb. Has anyone else had this issue and how did you fix it? Or is this just one of those Lucas quirks?
Old August 24th, 2011, 01:01 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Do you mean the battery light on the dash? If so then check all 3 wires on the back of the alt. 1 is the main and 1 is the exciter and 1 goes to the tach. Make sure they are tight on both ends of the wires and you can even check for resistance. Good luck.
ac, ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
