Tach goes to zero... - Defender Source
Old October 29th, 2008, 10:38 PM
Eddie Haskell
Aaron Haskell
1995 D90SW w/ ECR 4.6
...engine is still running...
...it hesitates some...
Could it be anything other than my alternator?
Many thanks.
Old October 29th, 2008, 10:43 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Nope.... Engine will run a while just on the battery....
Measure voltage at battery, if 13V+, then that's not the alternator. But.... I'd bet a lot on the alternator going south.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 31st, 2008, 02:13 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Could it be your serpentine belt tension pulley?
Old October 31st, 2008, 09:35 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
May be first sign of the alternator getting ready to fail.
Old November 1st, 2008, 12:39 AM
lrsafari
Scott Miller
1995 RRC LWB
Mine was doing that, and acting very erratic other times.
Based on a suggestion given to me, I moved my plug wires which were to close to the back of the alt, and fixed it. Bad wires on my rig. that said, some people also haev cured it by cleaning the attachment points on the alternator as well. apparently if it is slightly corroded you get the same effect.
Of course, probably your alternator on last breath Fortunately mine was bad wires and connections.
Old November 1st, 2008, 12:57 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Many thanks.
Usually I see this as a bad connection on the white/slate wire on the back of the alternator, especially on the diesels, due to vibration. As said in previous post, clean and check the wire on the back of the alt. before you do anything costly.
Email:
Old November 3rd, 2008, 11:25 AM
CDeWan
Clay DeWan
5.3L beastie
Could it be the pick up on the coil? I am not sure if the 4.6 had a coil or coil packs. If it has a coil, I would run some sand paper over the connections on both the positive and negavit sides. If it has coil packs and the engine is hesitating you may want to check the grounds on the coil packs.
Old November 3rd, 2008, 11:54 AM
ECR's Avatar
ECR
A 95 D90 gets it tach signal from the alternator.
Email:
ac
200tdi VDO tach settings tomaco1 Defender Technical Discussions 23 August 4th, 2011 09:16 AM
D90 tach or repl part rgrrvr Wanted 1 July 28th, 2008 09:43 PM
300tdi injector line OD- tiny tach D90user Defender Technical Discussions 0 June 18th, 2008 04:21 PM
tach question, sorry if redundant (warning) Neo Defender Technical Discussions 5 October 7th, 2005 04:24 PM
Tach works off and on mdmccallum Defender Technical Discussions 2 November 18th, 2004 07:25 PM
