T-case swap questions - Defender Source
Old February 3rd, 2014, 02:42 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Question T-case swap questions
I'm in the middle of swapping my 1.4 transfer case to a 1.2 from a disco and I've run into an issue that I need advice on. When I slid the new case onto the output shaft from the transmission it would not go on all the way. When I removed the inspection cover on the back of the t-case, it's got a round disc piece that fouls the output shaft of the transmission. The old 1.4 case does not have this piece. Everything else appears to be the same except the design of the inspection cover. Anyone who has swapped a disco case run into this and know if this piece can be removed? Advice is welcome!
ID:	89121   Click image for larger version
ID:	89123   Click image for larger version
Old February 3rd, 2014, 02:53 PM
Oil Feed Plate. An aftermarket device used to ensure lubrication of the LT77's output shaft splines. Looks like an LR unit. It can be removed, but the question remains why it does not fit into your input shaft gear (which it should.) It is preferable to keep it especially if you do not have a cross-drilled input gear.
Are you using the 1.4's input gear in the 1.2? What are the suffixes on the boxes?
Old February 3rd, 2014, 02:57 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
That is an oil feed disc. It was an in-service fix in 1994-1995 to get oil to the splines of the input gear to prevent spline wear on early gearboxes without cross drilled input gears. It fit applications with a ZF auto or R380. Late 1995 saw the introduction of the cross drilled input gears. You can remove it and drill the center hole larger to accomodate the threaded mainshaft of the LT77, remove it and throw it away and deal with eventual spline wear, or remove it and replace the input gear with a newer, cross drilled gear. If the LT230 is out of a Disco, it probably has a 28tooth input gear, in which case you need input gear P/N FTC5087.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 3rd, 2014, 03:04 PM
Yes, see if you have the cross drilled input gear before buttoning it all up.
Roadside rob is the lr transmission master in the US.
Old February 3rd, 2014, 03:25 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
Is there a way, by looking at the outside of the installed transfer case, to know if it's 1.2? I recall it was stamped on it somewhere....?
Old February 3rd, 2014, 03:44 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thumbs up
Thanks guys... I'll check the input gear when I get home, but if the oiler plate is there I doubt it's cross drilled. Probably end up drilling out the center of the plate per Rob since I'm not even sure I'll keep the 1.2 and it looks like the new gear is twice what I paid for the case.
Axel, I'm pretty sure my 1.4 is marked with something that looks like a sticker, but the 1.2 doesn't have anything on it. Might be able to tell from the serial numbers but I don't know the answer to that.
Old February 3rd, 2014, 03:58 PM
You can tell from the serial numbers. There is a decoder on ashcroft's website.
Old February 3rd, 2014, 10:52 PM
Axel's Avatar
Axel
jack
Thanks, Gentlemen.
Old February 21st, 2014, 12:23 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Does anyone know the torque requirement for the nut that holds the drive flange on the t-case? Can't seem to find it anywhere.
Old February 21st, 2014, 12:30 PM
108 to 132 lb-ft, but really the more the merrier.... Make sure you use new nuts or they work loose.
Do you not have the factory workshop manual?
Old February 21st, 2014, 01:57 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks John. No, I've only got a Haynes manual and I can't find it in there.
Old February 21st, 2014, 01:59 PM
Google will lead you to the factory manual for download.
Old February 28th, 2014, 11:42 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I've run into another issue with this swap. The disco case has an electronic speedo drive but still uses a square drive at the connection to the t-case so I thought the defender speedo cable would still work. But it turns out the square drive is a different size. Do I need to remove the rear casing to swap out the drive? Any one else swap a disco case into a defender and run across this?
Old February 28th, 2014, 11:50 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
You do not need to remove it to remove the rear drive gear. It may be a pain in the ass to yank out though
Legend in My Own Mind.
Old February 28th, 2014, 12:17 PM
You don't need to remove it if you can get the old one out. Mine was seized in place, so I pulled the rear off the case off, but that only takes a few minutes and some Right Stuff.
Old February 28th, 2014, 01:13 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Is it threaded or just friction fit? I did pry on it a little but it wasn't moving so I didn't pursue it. Of course I've already got everything back in the truck and the parking brake mounted so it's a lot harder to get to now...
Old February 28th, 2014, 02:17 PM
Better yet, keep the VSS and buy a VDO speedometer. You will then have an accurate speed and a gauge that can be seen day and night....
It is just friction fit.
Old February 28th, 2014, 02:22 PM
putting in a VDO speedo is easy and major upgrade in terms of usability and reliability
Old February 28th, 2014, 04:35 PM
go with the gps based vdo speedo
But you can fix what you have with a screwdriver gently pop the vss out and put the cable drive in.
Want to sell your 1.4 ?
Old February 28th, 2014, 04:44 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
How accurate are the gps units?
What happens when you are in an area where gps is not working like a canyon or tunnel?
Chassis swap questions Paul K Defender Technical Discussions 66 December 23rd, 2013 03:32 PM
Newbie chassis swap Questions cdansan Series Technical Discussions 12 September 2nd, 2013 12:44 PM
S IIa Transmission Swap Questions rlynch356 Series Technical Discussions 7 April 8th, 2012 08:48 PM
1993 Range rover transfer case swap easy Defender Technical Discussions 2 August 6th, 2009 10:18 PM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
