T-case swap questions - Page 2 - Defender Source
Old February 28th, 2014, 05:00 PM
very, goes away for a moment
http://www.usa.vdo.com/generator/www...ed_Sensor.html
Old February 28th, 2014, 05:59 PM
The VDO gauge would definitely be an upgrade. I had to use a punch to get that piece out of the rear housing.
Old February 28th, 2014, 11:28 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
go with the gps based vdo speedo
But you can fix what you have with a screwdriver gently pop the vss out and put the cable drive in.
Want to sell your 1.4 ?
I want to go VDO but I need to get this thing back on the road in time for SCARR in a few weeks so I'm going to have try to swap the drives. I'll sell you the 1.4 after I drive it with the 1.2 to be sure I want to keep it...
Old March 1st, 2014, 09:24 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Mike, I'll be interested to know how it works with a 1.2..........
Old March 1st, 2014, 09:43 AM
Ok. Let me know. 1.2 will be 15% taller gearing. My brother has a 1.2 in his 200tdi 110 pickup on 33's and loves it. Raub drove that truck @ Uwharrie and thought it drove like a sports car.
Old March 1st, 2014, 10:02 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
When you drive a 2.5 na with 33's anything drives like a sports car!!
Old March 24th, 2014, 02:27 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
So I've driven the truck a few days and overall I'm pleased with the 1.2. It's definitely easier to fall off the boost but I think once I get used to driving it it will be more appropriate gearing for me.
Unfortunately the truck has developed a heavy vibration on deceleration. I don't think this has anything to do with the t-case swap, but maybe? Any ideas appreciated - I'm supposed to drive 4 hrs to SCARR with the family this weekend...
Old March 24th, 2014, 02:46 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Output bearing
Rent my
Old March 24th, 2014, 02:47 PM
Or u-joint
Old March 24th, 2014, 02:51 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes, or UJ.
You can pull a driveshaft and see if the vibration goes away....but that won't tell you if it was in fact the DS or the corresponding output bearing.
Swap in a known good driveshaft and see if noise disappears.
Rent my
Chassis swap questions Paul K Defender Technical Discussions 66 December 23rd, 2013 03:32 PM
Newbie chassis swap Questions cdansan Series Technical Discussions 12 September 2nd, 2013 12:44 PM
S IIa Transmission Swap Questions rlynch356 Series Technical Discussions 7 April 8th, 2012 08:48 PM
1993 Range rover transfer case swap easy Defender Technical Discussions 2 August 6th, 2009 10:18 PM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
