T-case swap from 1.4 to 1.2 question - Page 2 - Defender Source
Old May 22nd, 2013, 12:29 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I think these are all you have to drill/tap to use an LT230 from a truck that originally came with a cable brake?
ID:	72863   Click image for larger version
Old May 22nd, 2013, 01:05 PM
Too easy! My buddy is going to swing by tomorrow and pick it up Joel. He has your number.
I'll report on here how it works out!
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 03:37 PM
Update: So I have Joel's 28D T-case now. Looks in good condition, recently rebuilt and everything is nice and tight. Just ordered a new input seal and thinking about the what other prep I need to do for this swap. Since this is coming out of a disco, it has more electronics than my 1.4. I can see it has an interlock solenoid. Can anyone tell me if that is something I can straight bolt off on swap with my t-case?
I also can see the oil temp sender and the neutral switch. I'm assuming I can remove those and replace with short bolts and washers for those from Home Depot to plug them up.
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 04:03 PM
Remove the shift solenoid. You just unbolt it, remove the solenoid and put the cover back on, sealing the hole where the wire went through.
You will probably have to drill and tap a couple of holes to mount the parking brake bracket.
I would just leave the switches in. They will probably be a weird thread size.
Old June 3rd, 2013, 04:07 PM
Good info, thanks
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 05:38 PM
By 'neutral' switch do you mean the diff lock indicator?
This one:
-Jeff
No. it's the switch that sits on top next to the interlock. Not relevant for Defenders.
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 05:58 PM
Originally Posted by jsbriggs View Post
i dont remember that one, but its been a while.
-jeff
Attachment 73696
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 07:38 PM
Sure enough. You could always wire in an idiot light
-Jeff
I think if the Tcase is in neutral accidentally, I't will become apparent pretty quick without the need for a light!
Mark Kellgren
KM4BOR
New transfer case 1.2 ratio pendy For Sale - Parts 0 September 27th, 2010 02:37 PM
1993 Range rover transfer case swap easy Defender Technical Discussions 2 August 6th, 2009 10:18 PM
Looking to Trade a 1.2 T-Case For a 1.4 TDI Guy Wanted 10 June 24th, 2009 10:06 PM
1.4 transfer case Joe P Misc. Chit-Chat 10 November 13th, 2007 08:01 PM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
