T-Case Replacement (How do you know?) - Defender Source
Old August 20th, 2012, 11:28 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Mornin' fellas.
My T-case is really starting to whine quite load - even with a fresh Mobile 1 Synthetic oil-change. How do you guys know when it's "time" to rebuild it? Do you let it die first?
Also... what parts do I want to change/replace/rebuild while I'm at it?
The truck ('97 NAS D90) has 135k miles.
Old August 20th, 2012, 11:37 AM
Probably best to do now. You most likely have a loose bearing. Just do a normal rebuild, bearings and seals. If you off road a one piece cross shaft for the center diff is a good idea.
Old August 20th, 2012, 04:15 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Are those items I would order from Ashcroft if I buy a rebuilt unit from them?
Old August 20th, 2012, 04:29 PM
Cross drilled input gear or an oiler plate so you dont wear the output splines on the transmission.
-Jeff
His 97 would already have crossdrilled shaft
Old August 20th, 2012, 04:44 PM
Naplm00
Matthew
My early D1 Tcase had the cross drilled shaft too
Of course: http://www.ashcroft-transmissions.co...ewCat&catId=52
Old August 20th, 2012, 05:00 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Originally Posted by Red90 View Post
I don't mean to sound like such a maroon. I just don't have the mechanical understanding that many of you guys do.
...which is why I really appreciate the help!
Old August 20th, 2012, 05:11 PM
How was the fluid that you drained? How much metal was on the drain plug?
Old August 20th, 2012, 05:19 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
I don't know. I had it done at the shop. They are very good at pointing things like that out when there is an issue.
Old August 20th, 2012, 07:13 PM
Maybe they didn't fill it back up.
ac
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
'94 Tansfer Case Replacement TravelerBT Defender Technical Discussions 5 December 30th, 2008 10:12 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
